I have two items: One to measure measure energy consumption and one to measure temperature and humidity. I want to display two values in the page cells and used the footer for this purpose. With my energy consumption it worked without problems. The result looks like this:
Your humidity sensor does not have state description metadata. I don’t know if your item has a displayState without that!? But you could give it a try.
Okay, I added the following meta description in the pattern of the humidity idem:
%.1f %%
…and it worked!
…and by changing the meta description to:
%.0f %%
…it doesn’t work anymore. I think this is strange behavior. I do not need the last digit. Why does it break just because I changed the decimal places to zero?
