Hello guys;
I am currently working on Temperature and Humidity ‘Data loger’ using Raspberry PI 3 and NodeMCU ESP8266 with DHT11.
in the item folder :
i
Number home_temp "Living Room [%.1f °C]" <temperature> {mqtt="<[mosquitto:MK-SmartHouse/security/temp:state:JSONPATH($.BME280.Temperature)]"}
As shown in the attached files: the code on screenshots and shows the problem of not displaying the values of temperature.
But when we display in CLI it works as shown in this screenshot
2019-04-26 19:04:18.251 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:04:18.391 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:04:26.778 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:04:41.088 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:04:43.799 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:04:53.674 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:05:20.751 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:05:24.054 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:39:47.770 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:39:49.817 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:39:59.313 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:42:27.675 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 19:48:28.097 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 20:30:41.820 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 21:43:52.615 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 21:53:00.480 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:40:26.628 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2019-04-26 22:42:15.615 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:42:19.138 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:42:20.140 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:42:20.808 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:45:07.576 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:45:08.147 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:45:08.642 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:45:09.116 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:45:30.253 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:45:30.564 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:45:30.884 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:45:31.218 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:46:04.344 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:46:04.857 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:46:52.921 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:46:53.247 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:46:53.615 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:46:53.928 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:48:25.600 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:48:25.897 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:48:26.211 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2019-04-26 22:48:26.618 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `home.sitemap` does not match the name `TestSiteMap` of the sitemap - please fix this as you might see unexpected behavior otherwise.
The Version of openHAB that we use is Openhab2.
the platform I am working on is : Openhab2
The version of the MQTT Binding I am using: binding-mqtt - 2.4.0
