Display two items on the same line
in the android app it is possible to display two “number” items on the same line.
for example: temperature and humidity?
thanks
You could make a String item and update that with string versions of your two numbers.
no, I need to have two different items on the same line at the same time
You could make a String item and update that with string versions of your two numbers. You can update that with a rule that triggers from a change of either source Number.
