I have a Deconz-DIYHue Setup and unfortunately I can’t use the Deconz binding (tons of exceptions thown in OpenHab) so I went with the Hue binding. The bridge is being found and the things can be set up, however my bridge keeps connecting and disconnecting
2019-08-19 14:54:37.750 [hingStatusInfoChangedEvent] - 'hue:bridge:1' changed from ONLINE to OFFLINE: Hue bridge connection lost.
2019-08-19 14:54:37.777 [hingStatusInfoChangedEvent] - 'hue:0210:1:light_garten_02' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-08-19 14:54:37.782 [hingStatusInfoChangedEvent] - 'hue:0210:1:light_garten_01' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-08-19 14:54:37.787 [hingStatusInfoChangedEvent] - 'hue:0210:1:light_wohnzimmer_02' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-08-19 14:54:37.993 [hingStatusInfoChangedEvent] - 'hue:bridge:1' changed from OFFLINE: Hue bridge connection lost. to ONLINE
I figured out the connect/disconnect events correspond with the polling interval.
How do I get rid of the disconnects? They’re spamming my log and persistence.
Thanks!
//edit:
When adding the bridge through PaperUI, the disconnects can bee seen in the logs as well. So it’s not a configuration issue. DIYHue works fine with the hue app on Android and iOS
2019-08-19 15:18:18.652 [hingStatusInfoChangedEvent] - 'hue:bridge:b827eb7fbb23' changed from ONLINE to OFFLINE: Hue bridge connection lost.
2019-08-19 15:18:18.660 [hingStatusInfoChangedEvent] - 'hue:bridge:b827eb7fbb23' changed from OFFLINE: Hue bridge connection lost. to ONLINE
