I’ve got some strange problem.
When I use the colorpicker for my RGBW LED strip, the 4th channel (White) don’t getting any DMX channel value’s
I’m using Openhab 1.8.3 with the dmx + OLA binding.
My item:
Color RGBW_LED "RGBW LED strip" (Kitchen) {dmx="CHANNEL[6/4:1000]"}
In the Android Openhab app, I get a Color circle and 2 sliders.
The left slider seems to be the white control, the right slider seems to be the brightness.
When I change the color and brightness, Everything works fine.
But when I use the white contol (left slider), there are no DMX values on the 4th channel.
It seems that the white balance is a combination of the first 3 channels (RGB).
When I use the webinterface of the openhab server, I get a color sphere and 1 slider (not 2!) for brightness. Also here I get no DMX value on channel 4.
How can I get the RGBW LED strip to work properly?
Do I need special configurations to get the 4th (white) channel to work?
thanks!
