Is it possible to control Led using the DMX protocol and linked to an lutron homeworks qs processor within openhab ? I know it is possible via telenet with the command output,ID,17,COLOR.
I cannot auto-discover the LED String but I am able to add it manually as a dimmer but then I do not have a correct control channel for the color.
Hi. Are you using the QSE-CI-DMX? There is no specific support in the binding for that right now, but I’ve been wanting to add it. If you are willing to test it out I can probably add support relatively quickly.
