Something odd has been happening in my attempts to upgrade OpenHAB to 2.1.0. I run my environment in Docker on a Ubuntu 16.04 LTS server. I flushed out userdata/tmp
and userdata/cache
, but the startup hangs when trying to bind a port for the Karaf SSH console:
2017-07-15 17:16:10.389 [DEBUG] [org.eclipse.osgi ] - FrameworkEvent STARTLEVEL CHANGED - org.eclipse.osgi
2017-07-15 17:16:10.389 [DEBUG] [org.apache.karaf.main.Main ] - Start level change complete.
2017-07-15 17:16:10.395 [DEBUG] [org.apache.karaf.shell.ssh ] - ServiceEvent REGISTERED - {org.apache.sshd.SshServer}={service.id=102, service.bundleid=26, service.scope=singleton} - org.apache.karaf.shell.ssh
2017-07-15 17:16:10.396 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.shell.ssh/4.0.8
2017-07-15 17:16:10.409 [DEBUG] [che.sshd.common.io.nio2.Nio2Acceptor] - Creating Nio2Acceptor
2017-07-15 17:16:10.410 [DEBUG] [che.sshd.common.io.nio2.Nio2Acceptor] - Binding Nio2Acceptor to address /127.0.0.1:8101
Nothing else is using port 8101, so I’m very confused as to why Karaf is freezing at this point. Nothing changes if I leave it alone for an hour, and neither restarting the container nor restarting the host fix the issue. Yet, I can still roll back to 2.0.0-amd64 if I flush the userdata/cache
and userdata/tmp
folders, so I’m guessing something changed in 2.1.0?
Here’s my docker-compose.yml file, just in case it helps:
services:
openhab-app:
container_name: openhab-app
devices:
- "/dev/ttyACM0:/dev/ttyACM0"
environment:
OPENHAB_HTTPS_PORT: '8443'
OPENHAB_HTTP_PORT: '8080'
USER_ID: '1033'
image: openhab/openhab:2.1.0-amd64
network_mode: "host"
restart: always
volumes:
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
- openhab_app_addons:/openhab/addons
- openhab_app_conf:/openhab/conf
- openhab_app_java:/openhab/.java
- openhab_app_userdata:/openhab/userdata
version: '3.2'
volumes:
openhab_app_addons:
external: true
openhab_app_conf:
external: true
openhab_app_java:
external: true
external: true
Has anyone else been successful upgrading using Docker?
