Two issues with the Pentair docs:
(1) pentair.thing extension should pentair.things or openhab wont pick up the file.
Thing Configuration
Currently automatic discovery is not supported and the binding requires configuration via the PaperUI or a file in the conf/things folder. Here is an example of a thing configuration file called ‘pentair.thing’:
(2) Syntax error in Full Example items file, the 12th line is missing the Number typename at the beginning.
Number PoolSetPoint “Pool Set Point [%.1f °F]” […snip]
If someone could correct, that would be great. Thanks!
