I‘ve discoverd the motion sensor HM-Sen-MDIR-WM55 from homemtic series.
As I’m using openHabian on a Raspberry PI I think this interface would be a good match.
Does anybody has experience with those components?
I’m using also a eqMAX! cube and related devices to controll the heating.
Would the MAX components work together with the above mentioned interface with openHab2?
The Max Cube sucks and I would like to get rid of it.
You can easily use both on one Raspberry PI if you move your devices to Homegear (Included in openHABian).
Homegear is also able to communicate with Max!, but needs a different radio adapter for that. (The HM-MOD-RPI-PCB is just able to talk to Homematic.) You also can just use one radio protocol at once per adapter.
So, to make it clear, you need two adapter to talk to Homematic and Max! at the same time, but if i am not mistaken, you may use the Max! cube with a different firmware as another radio adapter.
Oh, and by the way, the motion detector works fine, included is brightness and 2 pushbuttons (short, continuous and long press each).
