I have the same/similar error messages.
Platform information: macOS 10.13.6 (High Sierra), openHAB 4.3.7
Issue: UI throws java.util.concurrent.TimeoutException: Idle timeout expired
every ~10 sec
Other notes:
- openHAB UI in a browser works fine (Win11 + Chrome, or Android App, or Android + Chrome).
- same with all bindings disabled or enabled
- same with settings/services/org.openhab.network IPv6 enabled/disabled (but why lsof return IPv6 values? see at the end of the post)
- other returning lines are
[DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /openhab-3/userdata/etc/ ...
- I’m not sure wether it’s related or not, but I try to use midea ac bindings. Connection to my air conditioners are good. Channels are online. But when I toggle a power switch, the air conditioners usually (!) does not switch on (but openHAB UI says that it has switched on)
Extract from the log DEBUG:
192.168.0.200 is the IP of the macAir with openHAB
192.168.0.21 is the IP of a desktop PC opening the webUI of the openHAB (in Chrome)
0:09:34.285 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@2a39d3ee{null}
java.util.concurrent.TimeoutException: Idle timeout expired: 30004/30000 ms
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171) ~[?:?]
at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
10:09:34.287 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@55f3abc4{IDLE}->null
10:09:34.288 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@1fae36f3{l=/192.168.0.200:8080,r=/192.168.0.21:38776,OPEN,fill=-,flush=-,to=30008/30000}{io=0/0,kio=0,kro=1}->HttpConnection@24c04409[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3a5ced12{s=COMMITTED}]=>HttpChannelOverHttp@309b6ce8{s=HttpChannelState@53db1020{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=12,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600460}
10:09:38.624 [DEBUG] [com.github.mob41.blapi.BLDevice ] - Socket timed out for 29965 ms
java.net.SocketTimeoutException: Receive timed out
at java.net.PlainDatagramSocketImpl.receive0(Native Method) ~[?:?]
at java.net.AbstractPlainDatagramSocketImpl.receive(AbstractPlainDatagramSocketImpl.java:200) ~[?:?]
at java.net.DatagramSocket.receive(DatagramSocket.java:814) ~[?:?]
at com.github.mob41.blapi.BLDevice.discoverDevices(BLDevice.java:702) ~[?:?]
at org.openhab.binding.broadlinkthermostat.internal.discovery.BroadlinkThermostatDiscoveryService.createScanner(BroadlinkThermostatDiscoveryService.java:80) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
10:09:38.626 [DEBUG] [com.github.mob41.blapi.BLDevice ] - Converting list to array: 0
10:09:38.626 [DEBUG] [com.github.mob41.blapi.BLDevice ] - End of device discovery: 0
10:09:40.551 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@110f7151{l=/192.168.0.200:8080,r=/192.168.0.21:37825,OPEN,fill=-,flush=-,to=30003/30000}{io=0/0,kio=0,kro=1}->HttpConnection@688d6292[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@30a98c52{s=COMMITTED}]=>HttpChannelOverHttp@6795adc7{s=HttpChannelState@14c2d355{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=2,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=2101433} idle timeout check, elapsed: 30003 ms, remaining: -3 ms
10:09:40.552 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@110f7151{l=/192.168.0.200:8080,r=/192.168.0.21:37825,OPEN,fill=-,flush=-,to=30004/30000}{io=0/0,kio=0,kro=1}->HttpConnection@688d6292[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@30a98c52{s=COMMITTED}]=>HttpChannelOverHttp@6795adc7{s=HttpChannelState@14c2d355{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=2,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=2101434} idle timeout expired
10:09:40.553 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@333920c3{null}
java.util.concurrent.TimeoutException: Idle timeout expired: 30003/30000 ms
10:09:40.555 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@5f241059{IDLE}->null
10:09:40.557 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@110f7151{l=/192.168.0.200:8080,r=/192.168.0.21:37825,OPEN,fill=-,flush=-,to=30009/30000}{io=0/0,kio=0,kro=1}->HttpConnection@688d6292[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@30a98c52{s=COMMITTED}]=>HttpChannelOverHttp@6795adc7{s=HttpChannelState@14c2d355{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=2,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=2101439}
10:09:40.996 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@2cd90d52{l=/192.168.0.200:8080,r=/192.168.0.21:38795,OPEN,fill=-,flush=-,to=30003/30000}{io=0/0,kio=0,kro=1}->HttpConnection@76a8cd53[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@68b4bdca{s=COMMITTED}]=>HttpChannelOverHttp@5414e356{s=HttpChannelState@6faf6907{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600438} idle timeout check, elapsed: 30003 ms, remaining: -3 ms
10:09:40.997 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@2cd90d52{l=/192.168.0.200:8080,r=/192.168.0.21:38795,OPEN,fill=-,flush=-,to=30004/30000}{io=0/0,kio=0,kro=1}->HttpConnection@76a8cd53[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@68b4bdca{s=COMMITTED}]=>HttpChannelOverHttp@5414e356{s=HttpChannelState@6faf6907{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600439} idle timeout expired
10:09:40.999 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@454f4907{null}
10:09:41.001 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@cc6c915{IDLE}->null
10:09:41.004 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@2cd90d52{l=/192.168.0.200:8080,r=/192.168.0.21:38795,OPEN,fill=-,flush=-,to=30011/30000}{io=0/0,kio=0,kro=1}->HttpConnection@76a8cd53[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@68b4bdca{s=COMMITTED}]=>HttpChannelOverHttp@5414e356{s=HttpChannelState@6faf6907{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600446}
10:09:42.841 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@5ef1f262{l=/192.168.0.200:8080,r=/192.168.0.21:38801,OPEN,fill=-,flush=-,to=30003/30000}{io=0/0,kio=0,kro=1}->HttpConnection@56c8a068[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@47d540a3{s=COMMITTED}]=>HttpChannelOverHttp@41d1d3b3{s=HttpChannelState@3ccf2466{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=24,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=572489} idle timeout check, elapsed: 30003 ms, remaining: -3 ms
10:09:42.841 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@5ef1f262{l=/192.168.0.200:8080,r=/192.168.0.21:38801,OPEN,fill=-,flush=-,to=30004/30000}{io=0/0,kio=0,kro=1}->HttpConnection@56c8a068[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@47d540a3{s=COMMITTED}]=>HttpChannelOverHttp@41d1d3b3{s=HttpChannelState@3ccf2466{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=24,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=572490} idle timeout expired
10:09:42.841 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@1fae2650{null}
10:09:42.842 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@34bc1eea{IDLE}->null
10:09:42.844 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@5ef1f262{l=/192.168.0.200:8080,r=/192.168.0.21:38801,OPEN,fill=-,flush=-,to=30007/30000}{io=0/0,kio=0,kro=1}->HttpConnection@56c8a068[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@47d540a3{s=COMMITTED}]=>HttpChannelOverHttp@41d1d3b3{s=HttpChannelState@3ccf2466{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=24,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=572493}
^[[B10:09:46.020 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/log4j2.xml mod=1672647466180
10:09:46.021 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/keys.properties mod=1656279484000
10:09:46.023 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/users.properties mod=1663602042184
10:09:46.024 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/distribution.info mod=1656279484000
10:09:46.025 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/java.util.logging.properties mod=1656279492000
10:09:46.025 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/all.policy mod=1656279484000
10:09:46.026 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.felix.eventadmin.impl.EventAdmin.cfg mod=1663602039764
10:09:46.026 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.bundle.cfg mod=1663602039636
10:09:46.027 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/branding-ssh.properties mod=1656279492000
10:09:46.027 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/jmx.acl.org.apache.karaf.bundle.cfg mod=1663602039799
10:09:46.028 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.ops4j.pax.logging.cfg mod=1672647466275
10:09:46.028 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.jaas.cfg mod=1663602039745
10:09:46.029 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/keystore mod=1663603028054
10:09:46.029 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/jmx.acl.org.apache.karaf.config.cfg mod=1663602039851
10:09:46.029 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.config.cfg mod=1663602039782
10:09:46.030 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.system.cfg mod=1663602039620
10:09:46.030 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.features.xml mod=1656279484000
10:09:46.031 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.features.cfg mod=1663602039718
10:09:46.032 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.kar.cfg mod=1663602039623
10:09:46.032 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/jre.properties mod=1656279484000
10:09:46.033 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/system.properties mod=1656279486000
10:09:46.033 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/equinox-debug.properties mod=1656279484000
10:09:46.035 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.features.repos.cfg mod=1663602039649
10:09:46.036 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/overrides.properties mod=1656279492000
10:09:46.044 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.jaas.cfg mod=1663602039808
10:09:46.045 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.openhab.audio.cfg mod=1663602039856
10:09:46.046 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.feature.cfg mod=1663602039629
10:09:46.046 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.ops4j.pax.web.cfg mod=1663602039726
10:09:46.047 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/version.properties mod=1656279492000
10:09:46.048 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/config.properties mod=1663602037240
10:09:46.049 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/custom.system.properties mod=1656279492000
10:09:46.049 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/jetty.xml mod=1663603026025
10:09:46.050 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/profile.cfg mod=1663602039703
10:09:46.051 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.jupnp.cfg mod=1663602039705
10:09:46.053 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/branding.properties mod=1656279492000
10:09:46.054 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/custom.properties mod=1656279492000
10:09:46.054 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/startup.properties mod=1656279488000
10:09:46.055 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.shell.cfg mod=1663602039826
10:09:46.056 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.shell.cfg mod=1663602039609
10:09:46.057 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.kar.cfg mod=1663602039770
10:09:46.058 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.felix.fileinstall-deploy.cfg mod=1663602039756
10:09:46.059 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.scope_bundle.cfg mod=1663602039616
10:09:46.060 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.ops4j.pax.url.mvn.cfg mod=1663602039736
10:09:46.061 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.openhab.voice.cfg mod=1663602039652
10:09:46.062 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.log.cfg mod=1663602039711
10:09:46.062 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/shell.init.script mod=1656279492000
10:09:46.062 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scanned [/Users/eleklaszlosj/Downloads/openhab-3/userdata/etc]: null
10:09:46.196 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@3f6943fd{l=/192.168.0.200:8080,r=/192.168.0.21:38799,OPEN,fill=-,flush=-,to=30004/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3ab6de21[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3dad0ddc{s=COMMITTED}]=>HttpChannelOverHttp@2fe9e680{s=HttpChannelState@6f8bae87{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600453} idle timeout check, elapsed: 30004 ms, remaining: -4 ms
10:09:46.197 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@3f6943fd{l=/192.168.0.200:8080,r=/192.168.0.21:38799,OPEN,fill=-,flush=-,to=30005/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3ab6de21[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3dad0ddc{s=COMMITTED}]=>HttpChannelOverHttp@2fe9e680{s=HttpChannelState@6f8bae87{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600454} idle timeout expired
10:09:46.197 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@348e8a7f{null}
10:09:46.199 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@6a0e7555{IDLE}->null
10:09:46.201 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@3f6943fd{l=/192.168.0.200:8080,r=/192.168.0.21:38799,OPEN,fill=-,flush=-,to=30009/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3ab6de21[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3dad0ddc{s=COMMITTED}]=>HttpChannelOverHttp@2fe9e680{s=HttpChannelState@6f8bae87{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600458}
10:09:50.793 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@4351a49a{l=/192.168.0.200:8080,r=/192.168.0.21:38802,OPEN,fill=-,flush=-,to=30000/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3f75e646[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1f3e1248{s=COMMITTED}]=>HttpChannelOverHttp@67483543{s=HttpChannelState@7a83ef82{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600319} idle timeout check, elapsed: 30000 ms, remaining: 0 ms
10:09:50.794 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@4351a49a{l=/192.168.0.200:8080,r=/192.168.0.21:38802,OPEN,fill=-,flush=-,to=30001/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3f75e646[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1f3e1248{s=COMMITTED}]=>HttpChannelOverHttp@67483543{s=HttpChannelState@7a83ef82{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600320} idle timeout expired
10:09:50.794 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@6f3ff20{null}
java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
10:09:50.796 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@2b515a53{IDLE}->null
10:09:50.800 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@4351a49a{l=/192.168.0.200:8080,r=/192.168.0.21:38802,OPEN,fill=-,flush=-,to=30006/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3f75e646[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1f3e1248{s=COMMITTED}]=>HttpChannelOverHttp@67483543{s=HttpChannelState@7a83ef82{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=600326}
10:09:56.677 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@569c9cfe{l=/192.168.0.200:8080,r=/192.168.0.21:38775,OPEN,fill=-,flush=-,to=30001/30000}{io=0/0,kio=0,kro=1}->HttpConnection@4db1657a[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3971f337{s=COMMITTED}]=>HttpChannelOverHttp@25adbee7{s=HttpChannelState@1882547{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=633767} idle timeout check, elapsed: 30001 ms, remaining: -1 ms
10:09:56.688 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@569c9cfe{l=/192.168.0.200:8080,r=/192.168.0.21:38775,OPEN,fill=-,flush=-,to=30012/30000}{io=0/0,kio=0,kro=1}->HttpConnection@4db1657a[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3971f337{s=COMMITTED}]=>HttpChannelOverHttp@25adbee7{s=HttpChannelState@1882547{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=633778} idle timeout expired
10:09:56.693 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@4b430def{null}
java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
10:09:56.694 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@a8842e9{IDLE}->null
10:09:56.696 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@569c9cfe{l=/192.168.0.200:8080,r=/192.168.0.21:38775,OPEN,fill=-,flush=-,to=30020/30000}{io=0/0,kio=0,kro=1}->HttpConnection@4db1657a[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3971f337{s=COMMITTED}]=>HttpChannelOverHttp@25adbee7{s=HttpChannelState@1882547{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=1,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=633786}
10:09:59.515 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@32ec6a15{l=/192.168.0.200:8080,r=/192.168.0.21:38804,OPEN,fill=-,flush=-,to=30004/30000}{io=0/0,kio=0,kro=1}->HttpConnection@4388a5f9[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@5f0a3e35{s=COMMITTED}]=>HttpChannelOverHttp@633872bd{s=HttpChannelState@f371d32{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=7,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=602638} idle timeout check, elapsed: 30004 ms, remaining: -4 ms
10:09:59.517 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@32ec6a15{l=/192.168.0.200:8080,r=/192.168.0.21:38804,OPEN,fill=-,flush=-,to=30005/30000}{io=0/0,kio=0,kro=1}->HttpConnection@4388a5f9[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@5f0a3e35{s=COMMITTED}]=>HttpChannelOverHttp@633872bd{s=HttpChannelState@f371d32{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=7,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=602640} idle timeout expired
10:09:59.517 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@2a44e28c{null}
10:09:59.519 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@20f6268a{IDLE}->null
10:09:59.522 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@32ec6a15{l=/192.168.0.200:8080,r=/192.168.0.21:38804,OPEN,fill=-,flush=-,to=30010/30000}{io=0/0,kio=0,kro=1}->HttpConnection@4388a5f9[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@5f0a3e35{s=COMMITTED}]=>HttpChannelOverHttp@633872bd{s=HttpChannelState@f371d32{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=7,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=602644}
10:10:00.044 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@2e964271{l=/192.168.0.200:8443,r=/192.168.0.30:39624,OPEN,fill=-,flush=-,to=30003/30000}{io=0/0,kio=0,kro=1}->SslConnection@34d29193{NOT_HANDSHAKING,eio=-1/-1,di=-1,fill=IDLE,flush=IDLE}~>DecryptedEndPoint@1525153{l=/192.168.0.200:8443,r=/192.168.0.30:39624,OPEN,fill=-,flush=-,to=764472/30000}=>HttpConnection@57d11541[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@44dfc9ea{s=COMMITTED}]=>HttpChannelOverHttp@2d0f61df{s=HttpChannelState@60ef587b{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=5,c=false/false,a=WAITING,uri=https://192.168.0.200:8443/rest/events/states,age=761574} idle timeout check, elapsed: 30003 ms, remaining: -3 ms
10:10:00.044 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@19c5657{l=/192.168.0.200:8080,r=/192.168.0.21:37344,OPEN,fill=-,flush=-,to=30001/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3c88a911[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@5d1757e7{s=COMMITTED}]=>HttpChannelOverHttp@772caeb5{s=HttpChannelState@4535a08f{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=7,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=3178608} idle timeout check, elapsed: 30001 ms, remaining: -1 ms
10:10:00.045 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@2e964271{l=/192.168.0.200:8443,r=/192.168.0.30:39624,OPEN,fill=-,flush=-,to=30004/30000}{io=0/0,kio=0,kro=1}->SslConnection@34d29193{NOT_HANDSHAKING,eio=-1/-1,di=-1,fill=IDLE,flush=IDLE}~>DecryptedEndPoint@1525153{l=/192.168.0.200:8443,r=/192.168.0.30:39624,OPEN,fill=-,flush=-,to=764472/30000}=>HttpConnection@57d11541[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@44dfc9ea{s=COMMITTED}]=>HttpChannelOverHttp@2d0f61df{s=HttpChannelState@60ef587b{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=5,c=false/false,a=WAITING,uri=https://192.168.0.200:8443/rest/events/states,age=761575} idle timeout expired
10:10:00.047 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@19c5657{l=/192.168.0.200:8080,r=/192.168.0.21:37344,OPEN,fill=-,flush=-,to=30006/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3c88a911[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@5d1757e7{s=COMMITTED}]=>HttpChannelOverHttp@772caeb5{s=HttpChannelState@4535a08f{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=7,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=3178611} idle timeout expired
10:10:00.047 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@3a6c4c6e{null}
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113) ~[bundleFile:9.4.46.v20220331]
10:10:00.048 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@1053a06c{IDLE}->null
10:10:00.048 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@4988dddb{null}
10:10:00.050 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@2e964271{l=/192.168.0.200:8443,r=/192.168.0.30:39624,OPEN,fill=-,flush=-,to=30009/30000}{io=0/0,kio=0,kro=1}->SslConnection@34d29193{NOT_HANDSHAKING,eio=-1/-1,di=-1,fill=IDLE,flush=IDLE}~>DecryptedEndPoint@1525153{l=/192.168.0.200:8443,r=/192.168.0.30:39624,OPEN,fill=-,flush=-,to=764477/30000}=>HttpConnection@57d11541[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@44dfc9ea{s=COMMITTED}]=>HttpChannelOverHttp@2d0f61df{s=HttpChannelState@60ef587b{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=5,c=false/false,a=WAITING,uri=https://192.168.0.200:8443/rest/events/states,age=761580}
10:10:00.050 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@7b18741f{IDLE}->null
10:10:00.051 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@19c5657{l=/192.168.0.200:8080,r=/192.168.0.21:37344,OPEN,fill=-,flush=-,to=30010/30000}{io=0/0,kio=0,kro=1}->HttpConnection@3c88a911[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@5d1757e7{s=COMMITTED}]=>HttpChannelOverHttp@772caeb5{s=HttpChannelState@4535a08f{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=7,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=3178615}
10:10:00.052 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@51bccfb9{l=/192.168.0.200:8080,r=/192.168.0.21:37831,OPEN,fill=-,flush=-,to=30005/30000}{io=0/0,kio=0,kro=1}->HttpConnection@5d3a1ddf[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1f48efc6{s=COMMITTED}]=>HttpChannelOverHttp@62a58399{s=HttpChannelState@1ed34f10{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=2,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=2116903} idle timeout check, elapsed: 30005 ms, remaining: -5 ms
10:10:00.052 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@51bccfb9{l=/192.168.0.200:8080,r=/192.168.0.21:37831,OPEN,fill=-,flush=-,to=30005/30000}{io=0/0,kio=0,kro=1}->HttpConnection@5d3a1ddf[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1f48efc6{s=COMMITTED}]=>HttpChannelOverHttp@62a58399{s=HttpChannelState@1ed34f10{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=2,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=2116903} idle timeout expired
10:10:00.053 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@242b8eb2{null}
java.util.concurrent.TimeoutException: Idle timeout expired: 30005/30000 ms
10:10:00.055 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@6a4e66fb{IDLE}->null
10:10:00.060 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@51bccfb9{l=/192.168.0.200:8080,r=/192.168.0.21:37831,OPEN,fill=-,flush=-,to=30012/30000}{io=0/0,kio=0,kro=1}->HttpConnection@5d3a1ddf[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1f48efc6{s=COMMITTED}]=>HttpChannelOverHttp@62a58399{s=HttpChannelState@1ed34f10{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=2,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=2116910}
10:10:01.170 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/log4j2.xml mod=1672647466180
10:10:01.171 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/keys.properties mod=1656279484000
10:10:01.173 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/users.properties mod=1663602042184
10:10:01.174 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/distribution.info mod=1656279484000
10:10:01.175 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/java.util.logging.properties mod=1656279492000
10:10:01.176 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/all.policy mod=1656279484000
10:10:01.177 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.felix.eventadmin.impl.EventAdmin.cfg mod=1663602039764
10:10:01.178 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.bundle.cfg mod=1663602039636
10:10:01.179 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/branding-ssh.properties mod=1656279492000
10:10:01.180 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/jmx.acl.org.apache.karaf.bundle.cfg mod=1663602039799
10:10:01.181 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.ops4j.pax.logging.cfg mod=1672647466275
10:10:01.182 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.jaas.cfg mod=1663602039745
10:10:01.182 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/keystore mod=1663603028054
10:10:01.182 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/jmx.acl.org.apache.karaf.config.cfg mod=1663602039851
10:10:01.183 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.config.cfg mod=1663602039782
10:10:01.183 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.system.cfg mod=1663602039620
10:10:01.185 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.features.xml mod=1656279484000
10:10:01.185 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.features.cfg mod=1663602039718
10:10:01.186 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.kar.cfg mod=1663602039623
10:10:01.186 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/jre.properties mod=1656279484000
10:10:01.188 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/system.properties mod=1656279486000
10:10:01.190 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/equinox-debug.properties mod=1656279484000
10:10:01.191 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.features.repos.cfg mod=1663602039649
10:10:01.192 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/overrides.properties mod=1656279492000
10:10:01.193 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.jaas.cfg mod=1663602039808
10:10:01.194 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.openhab.audio.cfg mod=1663602039856
10:10:01.195 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.feature.cfg mod=1663602039629
10:10:01.196 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.ops4j.pax.web.cfg mod=1663602039726
10:10:01.196 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/version.properties mod=1656279492000
10:10:01.197 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/config.properties mod=1663602037240
10:10:01.198 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/custom.system.properties mod=1656279492000
10:10:01.198 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/jetty.xml mod=1663603026025
10:10:01.199 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/profile.cfg mod=1663602039703
10:10:01.200 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.jupnp.cfg mod=1663602039705
10:10:01.201 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/branding.properties mod=1656279492000
10:10:01.202 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/custom.properties mod=1656279492000
10:10:01.202 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/startup.properties mod=1656279488000
10:10:01.203 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.shell.cfg mod=1663602039826
10:10:01.203 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.shell.cfg mod=1663602039609
10:10:01.204 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.kar.cfg mod=1663602039770
10:10:01.205 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.felix.fileinstall-deploy.cfg mod=1663602039756
10:10:01.205 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.command.acl.scope_bundle.cfg mod=1663602039616
10:10:01.206 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.ops4j.pax.url.mvn.cfg mod=1663602039736
10:10:01.207 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.openhab.voice.cfg mod=1663602039652
10:10:01.207 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/org.apache.karaf.log.cfg mod=1663602039711
10:10:01.208 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scan accepted /Users/eleklaszlosj/Downloads/openhab-3/userdata/etc/shell.init.script mod=1656279492000
10:10:01.209 [DEBUG] [org.eclipse.jetty.util.Scanner ] - scanned [/Users/eleklaszlosj/Downloads/openhab-3/userdata/etc]: null
10:10:04.293 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@1fae36f3{l=/192.168.0.200:8080,r=/192.168.0.21:38776,OPEN,fill=-,flush=-,to=30003/30000}{io=0/0,kio=0,kro=1}->HttpConnection@24c04409[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3a5ced12{s=COMMITTED}]=>HttpChannelOverHttp@309b6ce8{s=HttpChannelState@53db1020{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=12,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=630465} idle timeout check, elapsed: 30003 ms, remaining: -3 ms
10:10:04.294 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@1fae36f3{l=/192.168.0.200:8080,r=/192.168.0.21:38776,OPEN,fill=-,flush=-,to=30004/30000}{io=0/0,kio=0,kro=1}->HttpConnection@24c04409[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3a5ced12{s=COMMITTED}]=>HttpChannelOverHttp@309b6ce8{s=HttpChannelState@53db1020{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=12,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=630466} idle timeout expired
10:10:04.294 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@2a39d3ee{null}
10:10:04.295 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - ignored: WriteFlusher@55f3abc4{IDLE}->null
10:10:04.296 [DEBUG] [org.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@1fae36f3{l=/192.168.0.200:8080,r=/192.168.0.21:38776,OPEN,fill=-,flush=-,to=30006/30000}{io=0/0,kio=0,kro=1}->HttpConnection@24c04409[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@3a5ced12{s=COMMITTED}]=>HttpChannelOverHttp@309b6ce8{s=HttpChannelState@53db1020{s=WAITING rs=ASYNC os=COMMITTED is=IDLE awp=false se=false i=false al=2},r=12,c=false/false,a=WAITING,uri=//192.168.0.200:8080/rest/events/states,age=630468}
10:10
extract from lsof -i -P n:
java 31788 eleklaszlosj 79u IPv6 0x4a19fc68246b4ef9 0t0 TCP *:8443 (LISTEN)
java 31788 eleklaszlosj 87u IPv6 0x4a19fc68246b2c79 0t0 TCP *:8080 (LISTEN)
java 31788 eleklaszlosj 131u IPv6 0x4a19fc68246b6039 0t0 TCP 127.0.0.1:58625 (LISTEN)
java 31788 eleklaszlosj 132u IPv6 0x4a19fc68246b4379 0t0 TCP 127.0.0.1:8101 (LISTEN)
java 31788 eleklaszlosj 153u IPv6 0x4a19fc68246b3239 0t0 TCP 192.168.0.200:8080->192.168.0.21:40494 (FIN_WAIT_2)
java 31788 eleklaszlosj 155u IPv6 0x4a19fc68323b7709 0t0 UDP *:5353
java 31788 eleklaszlosj 169u IPv6 0x4a19fc68246b26b9 0t0 TCP *:5007 (LISTEN)
java 31788 eleklaszlosj 200u IPv6 0x4a19fc68246b37f9 0t0 TCP 192.168.0.200:8080->192.168.0.21:40543 (CLOSE_WAIT)
java 31788 eleklaszlosj 203u IPv6 0x4a19fc68246b4939 0t0 TCP 192.168.0.200:8080->192.168.0.21:40545 (FIN_WAIT_2)
java 31788 eleklaszlosj 204u IPv6 0x4a19fc68246b5a79 0t0 TCP 192.168.0.200:8080->192.168.0.21:40546 (FIN_WAIT_2)
java 31788 eleklaszlosj 205u IPv6 0x4a19fc6826a246b9 0t0 TCP 192.168.0.200:8080->192.168.0.21:40547 (ESTABLISHED)
java 31788 eleklaszlosj 206u IPv6 0x4a19fc6826a26379 0t0 TCP 192.168.0.200:8080->192.168.0.21:40548 (FIN_WAIT_2)
assistant 45827 eleklaszlosj 11u IPv4 0x4a19fc6818626cc9 0t0 UDP *:*
@Robert_Daley : I think that you could change the title of this topic to something like “UI throws java.util.concurrent.TimeoutException every few seconds” or similar.
