Hello all!
OpenHAB has been running the thermostat for a while and it works fairly well. But periodically I’ll notice that it has quit communicating with the thermostat.
When I see this I’ll check to make sure the thermostat is still visible on the network, and it is.
Then open Putty and SSH to the RaspberryPi and issue various Curl commands to make sure I can interact with the thermostat from a command prompt, and I can.
All the while OpenHAB is reporting it hasn’t interacted with the thermostat for hours or a day or two… I track every update received with a timestamp to verify they are communicating.
This morning I enabled logging all http activity and first thing I noticed were lines with “doesn’t find matching binding provider” when the thermostat would update. What are these telling me? Because the items they are talking about do exist and are updated. You can see the results in the events file entries below.
Here is everything relative to the thermostat in my setup. And help greatly appreciated.
Thanks!
command prompt:
curl http://192.168.224.50/tstat/
{“temp”:66.50,“tmode”:1,“fmode”:0,“override”:0,“hold”:1,“t_heat”:67.00,“tstate”:0,“fstate”:0,“time”:{“day”:6,“hour”:9,“minute”:8},“t_type_post”:0}
http binding:
3M/Filtrete 50 Thermostat - heating/cooling info
http:tstat.url=http://192.168.224.50/tstat
refresh every 2 minutes
http:tstat.updateInterval=120000
items:
Number Tstat_mode “System Status” { http="<[tstat:120000:JSONPATH($.tmode)]" }
Number Tstat_temp “Indoor Temp [%.1f °F]” { http="<[tstat:120000:JSONPATH($.temp)]" }
Number Tstat_SetpointH “Set Heat Temperature [%.1f °F]” { http="<[tstat:120000:JSONPATH($.t_heat)]" }
Number Tstat_SetpointC “Set A/C Temperature [%.1f °F]” { http="<[tstat:120000:JSONPATH($.t_cool)]" }
Number Tstat_Setpoint “Set Temperature [%.1f °F]”
Number Tstat_hold “Hold Status” { http="<[tstat:120000:JSONPATH($.hold)]" }
Number Tstat_fan “Fan Mode” { http="<[tstat:120000:JSONPATH($.fmode)]" }
DateTime Tstat_LastUpdate “Last contact [%1$tm-%1$td @ %1$tH:%1$tM]”
rules:
// Get Current Heat/AC Target Temperature - load Setpoint
rule “New Target Temperature”
Item Tstat_mode received update
if (Tstat_mode.state == 1) {
Tstat_Setpoint.state = Tstat_SetpointH.state
if (Tstat_mode.state == 2) {
Tstat_Setpoint.state = Tstat_SetpointC.state
***there are other rules to set temp, heat/cool mode etc but the above rule is the only one that triggers querying the thermostat
sitemap:
Switch item=Tstat_mode mappings=[0=“Off”, 1=“Heat”, 2=“Cool”] icon=“thermometer”
Setpoint item=Tstat_Setpoint minValue=60 maxValue=80 step=1.0
Switch item=Tstat_hold mappings=[0=“No”, 1=“Yes”]
Switch item=Tstat_fan mappings=[0=“Auto”, 2=“On”] icon=“fan”
Text item=Tstat_LastUpdate
openhab.log:
2015-11-15 09:14:28.486 [DEBUG] [.o.b.http.internal.HttpBinding] - item ‘Tstat_mode’ is fetched from cache
2015-11-15 09:14:28.489 [DEBUG] [.o.b.http.internal.HttpBinding] - transformed response is ‘1’
2015-11-15 09:14:28.491 [TRACE] [.o.b.http.internal.HttpBinding] - doesn’t find matching binding provider [itemName=Tstat_mode, command=CHANGED]
2015-11-15 09:14:35.497 [DEBUG] [.o.b.http.internal.HttpBinding] - item ‘Tstat_temp’ is fetched from cache
2015-11-15 09:14:35.500 [DEBUG] [.o.b.http.internal.HttpBinding] - transformed response is ‘67.0’
2015-11-15 09:14:35.503 [TRACE] [.o.b.http.internal.HttpBinding] - doesn’t find matching binding provider [itemName=Tstat_temp, command=CHANGED]
2015-11-15 09:14:35.503 [DEBUG] [.o.b.http.internal.HttpBinding] - item ‘Tstat_SetpointH’ is fetched from cache
2015-11-15 09:14:35.506 [DEBUG] [.o.b.http.internal.HttpBinding] - transformed response is ‘67.0’
2015-11-15 09:14:35.508 [DEBUG] [.o.b.http.internal.HttpBinding] - item ‘Tstat_SetpointC’ is fetched from cache
2015-11-15 09:14:35.512 [DEBUG] [.o.b.http.internal.HttpBinding] - transformed response is ‘null’
2015-11-15 09:14:35.515 [DEBUG] [.o.b.http.internal.HttpBinding] - Couldn’t create state of type ‘class org.openhab.core.library.items.NumberItem’ for value ‘null’
2015-11-15 09:14:35.517 [DEBUG] [.o.b.http.internal.HttpBinding] - item ‘Tstat_hold’ is fetched from cache
2015-11-15 09:14:35.520 [DEBUG] [.o.b.http.internal.HttpBinding] - transformed response is ‘1’
2015-11-15 09:14:35.523 [DEBUG] [.o.b.http.internal.HttpBinding] - item ‘Tstat_fan’ is fetched from cache
2015-11-15 09:14:35.527 [DEBUG] [.o.b.http.internal.HttpBinding] - transformed response is ‘0’
2015-11-15 09:14:35.530 [TRACE] [.o.b.http.internal.HttpBinding] - doesn’t find matching binding provider [itemName=Tstat_SetpointH, command=CHANGED]
2015-11-15 09:14:35.537 [TRACE] [.o.b.http.internal.HttpBinding] - doesn’t find matching binding provider [itemName=Tstat_SetpointC, command=CHANGED]
2015-11-15 09:14:35.552 [TRACE] [.o.b.http.internal.HttpBinding] - doesn’t find matching binding provider [itemName=Tstat_hold, command=CHANGED]
2015-11-15 09:14:35.559 [TRACE] [.o.b.http.internal.HttpBinding] - doesn’t find matching binding provider [itemName=Tstat_fan, command=CHANGED]
events.log:
2015-11-15 09:14:28 - Tstat_mode state updated to 1
2015-11-15 09:14:35 - Tstat_temp state updated to 67.0
2015-11-15 09:14:35 - Tstat_SetpointH state updated to 67.0
2015-11-15 09:14:35 - Tstat_SetpointC state updated to null
2015-11-15 09:14:35 - Tstat_hold state updated to 1
2015-11-15 09:14:35 - Tstat_fan state updated to 0
2015-11-15 09:14:35 - Tstat_LastUpdate state updated to 2015-11-15T09:14:35
