Did you manage to find a way to make the input buttons light state change when a light is triggered by openhab in openhab? I don’t quite understand how to cibfigure the input buttons in openhab.
Another way might be to create variables in the domintell software that would change the button light state when a light is on but I think it might not be a good idea to mix the actions of openhab and domintell.
Is is automatically handled by Domintell. You need to define Followers in Domintell configuration application and link the output light and the input indicator led.
I also own DTRVBT01 (low voltage motor controller) and DAXLCD02-LG (lcd touch screen for up to 4 buttons) but they are not plugged to my system but I could plug them for testing purpose.
In order to recover my installation in case of problem, I’m trying to recreate my things and items manually instead of via PaperUI but I’m facing an issue.
When I create my thing file as described in the readme.md file I get this error :
Configuration model 'ModuleRelais.things' has errors, therefore ignoring it: [1,51]: missing EOF at '\'
I think it’s been auto pasted when I copied it from browser to Xcode
It seems to work but I get this now:
Cannot add "BridgeImpl" with key "domintell:bridge:DETH02". It exists already from provider "ManagedThingProvider"! Failed to add a second with the same UID from provider "GenericThingProvider"!
So I assume I have to remove the bridge first from Paper UI.
I think you should delete the binding (remove it from addons), stop OH, clear userdata/tmp and userdata/cache (only content should be deleted!!!), start OH without the binding, install the binding (copy into addons folder) and then add the things file.
I just deleted the things and created the things and items files.
I gave the item the exact same name that Paper UI gave them.
Now everything works like a charm.
Now Gabor, if you have time and now that I understand better what I’m doing with OH, could you tell me what you would need to try to make the controlled plugs (DTRP01) work?
Well I closed the PR today as it seems there’s only few of us with Domintell background - it will not be merged and it will not become part of the official OH package… If I’ll find some spare time I’ll add DTRP01 support and send you my locally built binary.
