No, it’s not that. You can have two different Item names with just one character in a different case.
I suspect more likely is some “debris” associated with the particular Item name. Sometimes broken links get left in openHABs internal JSONDB, and mess stuff up. They’re difficult to track down.
EDIT - there is a utility to make this easier in OH3
It’s always smart to make a backup before tinkering with this
I used the org.openhab.binding.homematic-3.1.0-SNAPSHOT.jar. in my previous OH3.1M3 & M4 version, which fixed the issue.
When I updated to 3.1.0M5 last week I removed this add-on an use the binding provided in the M5, as I thought this release uses the SNAPSHOT provided long time ago.
However this seems to be the case, as the Homematic things are not updated again.
Do I still need to use the SNAPSHOT in M5 release, or is this a different problem?
in the last months I have tried several implementations to make the connection especially for HmIP items more stable. But none of the solutions really worked reliably and therefore none of them made it into a PR and into the milestones. In my opinion the support of HmIP devices in the normal CCU is really buggy and testing solutions for this problems is really a nightmare.
I now have at home a HmIP devices that also sometimes has problems with state updates which helps a bit to find a reliable solution.
Can you describe a bit more in detail your exact problem? Do to the update stop after a certain period or was the connection between OH and the CCU interrupted for a certain time and nocht completely restored?
Hey guys
How the situation today? I have still the same problem the Gateway-Extras will not be updated in OpenHAB.
No worries from OH to Raspberrymatic. Any suggestions?
the behavior disappeared after removing/re-adding the Gateway thing.
However, each time I update the CCU software, the problem occurs again. After rebooting the CCU some things are not getting updated.
Although the Gateway shows online, it doesn’t work anymore.
To make it work again, it’s sufficient to “disable” the Gateway thing and “enable” it again in OH.
Not sure the same approach will help you, but its worth to test
