I have a gardena mower working perfectly with the gardena binding.
In my Sitemap i have
xxxx
Text item=Maeherstatus icon=mower
Text item=NextStart icon="time"
xxxx
on items i have this
xxx
String Maeherstatus “Status [MAP(gardena.map):%s]” {channel=“gardena:mower:home:myMower:mower#status”}
DateTime NextStart “Nächster Start [%1$td.%1$tm.%1$ty %1$tH:%1$tM:%1$tS]”{channel=“gardena:mower:home:myMower:mower#timestamp_next_start”}
xxx
(The Map only translate the english commands to german)
But if the if the state of Maeherstatus change to “ok_cutting” i always see on NextStart the Dummy date: 31.12.1969 23:00:00. I just want to hide this or it should be set to 0
If Maeherstatus change to charging it shows me correctly the NextStart Time.
So how can i solve this problem i tried with serveral rules String Comparision also with Visibilty in Sitemap but still not working.
Maybe some one has a clue
