I am looking for a contact sensor for my door. I tried some insteon sensors but they seemed to have a very slow response time and would get confused if opened and closed quickly.
I also noticed that if it was opened and closed within 1 second openhab would not see the state correctly. Everything tells me its the insteon sensor itself. I detected this problem on the bench, however once installed on my door it had an issue missing states also. Here is my question:
Is there a sensor that can detect open/close within .5secs without a problem. The scenario would be you open the door and realize you forgot something and close immediately. It should handle this state change with no issue. I am looking at zwave sensors, but I would like if someone could give me feedback prior to making a purchase.
Thanks!
