Door sensor does not send status to openhab2
I would do the following:
– Set the zwave traces to DEBUG and check if there is communication between the sensor and then main controller when you wake up the device
– Try opening / closing door to see if there are any messages sent back and forth
– Delete the channel association and recreate it
– Delete the sensor from openhab via habadmin. It will not remove the sensor from the zwave network but only from openhab. You can add it back in and normally it will keep all the channel configuration
– Try resetting the sensor. From the fibaro manual
Resetting the Door/Window Sensor
Reset procedure deletes EEPROM’s memory, including all information
on the Z-Wave network and the main controller.
     1. Open the cover.
     2. Remove the battery.
     3. Install the battery while holding both TMP buttons.
     4. Release the TMP button within 5 seconds.
     5. Visual indicator will blink 3 times to confirm launching of reset
         procedure.
     6. Wait around 30s for the resetting process to end, do not remove
         the battery.
     7. Visual LED indicator will blink 6 times to confirm the reset.
I was troubleshooting a fibaro motion sensor who had been constantly ON for some reason and did all the above. The reset had finally fixed the issue. The side effect was that when I added it back it got a higher node ID in the zwave network while it kept also the old ID (ghost ID). Good news is that I removed the ghost device by using zensys tools and this post
Hope this helps
Christos
