Hi Christos,
I just have seen your answer. Thanks for your advice.
I will try that later, when I’m back home.
Edit: I did as you recommended, but I can’t get FGK101 work, neverless it shows batterylevel and status closed.
The sensor don’t change items, when opening or closing the door.
Yes, there is communication when waking up the device. (NODE 12)
13:46:23.663 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 1D 00 49 84 0C 17 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 86 84 D3
13:46:23.689 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:46:23.697 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 1D 00 49 84 0C 17 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 86 84 D3
13:46:23.704 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 1D 00 49 84 0C 17 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 86 84 D3
13:46:23.711 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationUpdate[0x49], type=Request[0x00], priority=High, dest=255, callback=0, payload=84 0C 17 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 86 84
13:46:23.712 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 12: Application update request. Node information received.
13:46:23.713 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
13:46:23.714 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@d87106 already registered
13:46:23.715 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Is awake with 0 messages in the wake-up queue.
13:46:23.716 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveWakeUpEvent
13:46:23.716 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveWakeUpEvent
13:46:23.720 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=182, payload=0C 02 84 08
13:46:23.726 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationUpdate[0x49], type=Request[0x00], priority=High, dest=255, callback=0, payload=84 0C 17 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 86 84
13:46:23.728 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationUpdate, callback id=182, expected=SendData, cancelled=false MISMATCH
13:46:24.719 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: No more messages, go back to sleep
13:46:24.720 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
13:46:24.722 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
13:46:24.722 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
13:46:24.725 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 0C 02 84 08 25 B7 F5
13:46:24.727 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 09 00 13 0C 02 84 08 25 B7 F5
13:46:24.738 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
13:46:24.769 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:46:24.784 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
13:46:24.786 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
13:46:24.786 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 B7 00 00 02 5E
13:46:24.788 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
13:46:24.789 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: Sent Data successfully placed on stack.
13:46:24.809 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:46:24.812 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 B7 00 00 02 00 00 50
13:46:24.814 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 B7 00 00 02 00 00 50
13:46:24.816 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=B7 00 00 02
13:46:24.817 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 183, Status = Transmission complete and ACK received(0)
13:46:24.818 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
13:46:24.819 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@d87106 already registered
13:46:24.821 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=183, payload=0C 02 84 08
13:46:24.823 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=B7 00 00 02
13:46:24.825 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=183, expected=SendData, cancelled=false transaction complete!
13:46:24.825 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
13:46:24.827 [DEBUG] [curityCommandClassWithInitialization] - NODE 12: updating lastSentMessageTimestamp
13:46:24.827 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Went to sleep
13:46:24.828 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Is sleeping
13:46:24.830 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
13:46:24.831 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 12: Response processed after 82ms/3902ms.
And also when open/close the door (see ERROR: NODE 12: Endpoint 0 not found. Cannot set command classes.)
13:50:31.016 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 0C 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00 1F
13:50:31.039 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:50:31.042 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 13 00 04 00 0C 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00 1F
13:50:31.044 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 13 00 04 00 0C 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00 1F
13:50:31.046 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00
13:50:31.047 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (ALIVE:DONE)
13:50:31.048 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
13:50:31.049 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@d87106 already registered
13:50:31.050 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class MULTI_INSTANCE
13:50:31.050 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 12: Received MULTI_INSTANCE command V0
13:50:31.051 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 12: Requested Command Class = ALARM (0x71)
13:50:31.052 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 12: Endpoint 0 not found. Cannot set command classes.
13:50:31.053 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=186, payload=0C 02 84 08
13:50:31.056 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00
13:50:31.056 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=186, expected=SendData, cancelled=false MISMATCH
Deleting channel associations, and also deleting the sensor from openHAB didn’t change anything.
Also, I reset the sensor. I’ve done it as described on the Fibaro website http://manuals.fibaro.com/door-window-sensor/ which is different to your description.
What’s confusing me is, like I told in post #3 I have an older FGK101 that works.
But all four new, which I bought later, are showing the same behavior.
@chris Could you please have a look at my logs, and tell me what’s your opinion? From my point of view, the 4 new sensors are broken and I have to send them back to my vendor.
