I modified a 10 euro doorbell from Grundig with a wemos running ESPEasy.
When someone hits the switch it should automatically send a message with a screenshot of the camera.
I changed some permissions but I’m unsure how to fix it properly.
I created a rule:
import org.openhab.core.library.types.*
rule "Hall_DoorBell"
Item Hall_DoorBell received command ON
executeCommandLine("ffmpeg -i rtsp://192.168.1.12/live2.sdp -f image2 -vframes 1 /etc/openhab2/html/screenshots/pic.jpg")
sendMail("mgkooi@gmail.com", "Hall_DoorBell gaat.", "Er staat iemand voor de deur","http://192.168.1.20:8080/static/screenshots/pic.jpg")
sendTelegramPhoto("bot1", "http://192.168.1.20:8080/static/screenshots/pic.jpg", "Hall_DoorBell gaat")
executeCommandLine("rm /etc/openhab2/html/screenshots/pic.jpg")
sendCommand(Hall_DoorBell, OFF)
This is the permission of the file:
[22:39:15] openhabian@openhab:/etc/openhab2/html$ ls -l /etc/openhab2/html/screenshots/
total 32
-rw-rw-r-- 1 openhab openhab 32537 Nov 8 22:39 pic.jpg
But in the log I see this error(s):
22:39:36.253 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hall_DoorBell' received command ON
22:39:36.256 [INFO ] [marthome.event.ItemStateChangedEvent] - Hall_DoorBell changed from OFF to ON
22:39:36.268 [INFO ] [lipse.smarthome.io.net.exec.ExecUtil] - executed commandLine 'ffmpeg -i rtsp://192.168.1.12/live2.sdp -f image2 -vframes 1 /etc/openhab2/html/screenshots/pic.jpg'
22:39:36.291 [ERROR] [rg.openhab.action.mail.internal.Mail] - Error adding attachment to email.
org.apache.commons.mail.EmailException: Invalid URL set:http://192.168.1.20:8080/static/screenshots/pic.jpg
at org.apache.commons.mail.MultiPartEmail.attach(MultiPartEmail.java:395)
at org.apache.commons.mail.MultiPartEmail.attach(MultiPartEmail.java:339)
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:120)
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:89)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_121]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_121]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_121]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_121]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:114)[129:org.eclipse.smarthome.model.script:0.9.0.b5]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:77)[130:org.eclipse.smarthome.model.script.runtime:0.9.0.b5]
at org.eclipse.smarthome.model.script.engine.ScriptExecutionThread.run(ScriptExecutionThread.java:42)[129:org.eclipse.smarthome.model.script:0.9.0.b5]
Caused by: java.io.FileNotFoundException: http://192.168.1.20:8080/static/screenshots/pic.jpg
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1872)[:1.8.0_121]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)[:1.8.0_121]
at java.net.URL.openStream(URL.java:1045)[:1.8.0_121]
at org.apache.commons.mail.MultiPartEmail.attach(MultiPartEmail.java:390)
... 22 more
22:39:37.679 [ERROR] [ab.action.telegram.internal.Telegram] - Method failed: HTTP/1.1 404 Not Found
22:39:37.685 [INFO ] [lipse.smarthome.io.net.exec.ExecUtil] - executed commandLine 'rm /etc/openhab2/html/screenshots/pic.jpg'
22:39:37.699 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hall_DoorBell' received command OFF
22:39:37.711 [INFO ] [marthome.event.ItemStateChangedEvent] - Hall_DoorBell changed from ON to OFF
The file is created successfully by the rule but it cannot be found by the rule but it is actually there
Also when hitting the bell changes 8 times to state ON.
Is it possible to check that in the rule like:
(Item Hall_DoorBell received command ON).count=8
