Doorbird Binding: Channel Update
Hello, I am using the doorbird-binding with openHAB 3.3.0.M1.
No I experienced that the channels with pictures are not always updating automatically.
For example the item for the channel “Doorbell Montage Image” does not update with a new Doorbell-press.
When I link a new item to the existing ones the channel will update and the picture changes.
Is there something wrong with my setup? Or is there a way to trigger the update of the channel from openhab?
Thank you in advance. BR
You can send the command “REFRESH” to the channel.
Perfect, tank you. I did not know this.
After your hind I also found it here:
Maybe I find a way to edit the docs because it is not described there.
