Hi all,
I am getting weird… ;-). Since a reinstall - because of another problem - my doorbird does not work like i want it to.
The thing is showed only. The DoorbellMotion-Item works fine. But the DoorbellPressed does not work… and everything is correct, or i am blind.
Thing doorbird:d101:doorbell “Doorbird D101 Doorbell Erbstadt” [doorbirdHost=“myip]”,userId=“ghalac0000”,userPassword=“mypassword]”,imageRefreshRate=60,doorbellOffDelay=3,motionOffDelay=30,montageNumImages=3,montageScaleFactor=35]
Switch DoorbellPressed "Doorbell Pressed [%s]" <switch> { channel="doorbird:d101:doorbell:doorbell" [profile="rawbutton-on-off-switch"] }Switch DoorbellMotion “Doorbell Motion [%s]” { channel=“doorbird:d101:doorbell:motion” }
DateTime DoorbellPressedTimestamp “Doorbell Pressed Timestamp [%1$tA, %1$tm/%1$td/%1$tY %1$tl:%1$tM %1$tp]” { channel=“doorbird:d101:doorbell:doorbellTimestamp” }
Image DoorbellPressedImage “Doorbell Pressed Image [%s]” { channel=“doorbird:d101:doorbell:doorbellImage” }
DateTime DoorbellMotionTimestamp “Doorbell Motion Timestamp [%1$tA, %1$tm/%1$td/%1$tY %1$tl:%1$tM %1$tp]” { channel=“doorbird:d101:doorbell:motionTimestamp” }
Image DoorbellMotionDetectedImage “Motion Detected Image [%s]” { channel=“doorbird:d101:doorbell:motionImage” }
Switch DoorbellLight “Doorbell Light [%s]” { channel=“doorbird:d101:doorbell:light”, expire=“5s,command=OFF” }
Switch DoorbellOpenDoor1 “Doorbell Open Door 1 [%s]” { channel=“doorbird:d101:doorbell:openDoor1”, expire=“5s,command=OFF” }
Image DoorbellImage “Doorbell Image [%s]” { channel=“doorbird:d101:doorbell:image” }
Number DoorbellDoorbellHistoryIndex “Doorbell History Index [%.0f]” { channel=“doorbird:d101:doorbell:doorbellHistoryIndex” }
DateTime DoorbellDoorbellHistoryTimestamp “Doorbell History Timestamp [%1$tA, %1$tm/%1$td/%1$tY %1$tl:%1$tM %1$tp]” { channel=“doorbird:d101:doorbell:doorbellHistoryTimestamp” }
Image DoorbellDoorbellHistoryImage “Doorbell History Image [%s]” { channel=“doorbird:d101:doorbell:doorbellHistoryImage” }
Number DoorbellMotionHistoryIndex “Motion History Index [%.0f]” { channel=“doorbird:d101:doorbell:motionHistoryIndex” }
DateTime DoorbellMotionHistoryTimestamp “Motion History Timestamp [%1$tA, %1$tm/%1$td/%1$tY %1$tl:%1$tM %1$tp]” { channel=“doorbird:d101:doorbell:motionHistoryTimestamp” }
Image DoorbellMotionHistoryImage “Motion History Image [%s]” { channel=“doorbird:d101:doorbell:motionHistoryImage” }
Image DoorbellDoorbellMontage “Doorbell History Montage [%s]” { channel=“doorbird:d101:doorbell:doorbellMontage” }
Image DoorbellMotionMontage “Motion History Montage [%s]” { channel=“doorbird:d101:doorbell:motionMontage” }
For example a rule … something like my personal goal:
rule "DoorBirdEventKlingel"when
Item DoorbellPressed changed to ON
logInfo(“doorbird”, “Ein Besucher klingelt.”)
echo_beamer_TTS.sendCommand(“Ein Besucher steht vor der Tür.”)
echo_masterbad_TTS.sendCommand(“Ein Besucher steht vor der Tür.”)
echo_gaestebad_TTS.sendCommand(“Ein Besucher steht vor der Tür.”)
echo_schlafzimmer_TTS.sendCommand(“Ein Besucher steht vor der Tür.”)
echo_studio_TTS.sendCommand(“Ein Besucher steht vor der Tür.”)
The logfile shows that, when i ring the bell:
2020-12-29 18:15:18.082 [vent.ItemStateChangedEvent] - DoorbellMotion changed from OFF to ON
But neither DoorbellPressed is triggered, not p. ex. the DoorbellPressedTimestamp is updated.
I already cleared the cache and rebootet the system several times.
Thanks for every little clue!!!
Patrick
