Yes, the file was installed correctly by the binding and all the permissions were already enabled on this file and the directory.
When the OS library is loaded (libsodium.so.18.1.1), no permission problem anymore but still nok
2020-01-15 20:24:05.957 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.NoClassDefFoundError: Could not initialize class org.openhab.binding.doorbird.internal.listener.DoorbirdEvent$LazySodiumJavaHolder
at org.openhab.binding.doorbird.internal.listener.DoorbirdEvent.getLazySodiumJavaInstance(DoorbirdEvent.java:100) ~[?:?]
at org.openhab.binding.doorbird.internal.listener.DoorbirdEvent.decryptV1(DoorbirdEvent.java:181) ~[?:?]
at org.openhab.binding.doorbird.internal.listener.DoorbirdEvent.decrypt(DoorbirdEvent.java:159) ~[?:?]
at org.openhab.binding.doorbird.internal.listener.DoorbirdUdpListener.processPacket(DoorbirdUdpListener.java:122) ~[?:?]
at org.openhab.binding.doorbird.internal.listener.DoorbirdUdpListener.receivePackets(DoorbirdUdpListener.java:95) ~[?:?]
at org.openhab.binding.doorbird.internal.listener.DoorbirdUdpListener.run(DoorbirdUdpListener.java:65) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_231]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_231]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_231]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_231]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_231]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_231]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_231]
2020-01-15 20:24:05.990 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
I installed the Doorbird Binding and set everything up. The binding detects that Doorbird is online but it does not show any value of the items in paper ui Control.
The Openhabian and Doorbird are connected to the same switch so they should be able to exchange status.
Any idea what could be wrong?
Unfortunately I cannot find any log entries on Doorbird.
Do you see the item state events being posted in events.log? What about trying Basic UI instead of the Control section of Paper UI?
After that, the next step would be to put the binding in DEBUG mode (log:set DEBUG org.openhab.binding.doorbird in the console) followed by a stop/start of the binding. Then post the log output.
The released version of the binding doesnât yet include support for the A1081. Therefore, you first need to uninstall the binding, then use the binding jar file here.
Yes. Uninstall the doorbird addon that was installed using either PaperUI or addons.cfg. Then once thatâs uninstalled, download the doorbird jar from the above link, then copy into your addons directory.
Could you be a bit more specific? The current image comes directly from the doorbird device. Historical images (which are used for the monatge images) come from the Doorbird cloud service (through the doorbird device).
Can you describe what you want to achieve using SIP?
I have a VoIP server on my LAN so for fun I created an extension for the Doorbird and configured it in the Doorbird app. That let me call the Doorbird from the SIP client on my phone. I havenât really found a use for it yet other than to talk to my cat when sheâs sitting on the doorstep.
higgers, I use this, but use the Doorbird to cal my SIP Phone when the call button on the Doorbird is pressed. Thatâs the real use! The Doorbird App is too slow here in Australia
Here is my rule that does that:
rule "Send request for DoorBird back call"
Channel "doorbird:d210x:1059f9d4:doorbell" triggered PRESSED
sendHttpGetRequest("http://user:password@192.168.0.141/bha-api/sip.cgi?action=makecall&url=sip:1003@192.168.0.6")
logInfo("DoorBird", "SIP Call from Doorbird")
Possibly. But, the doorbird is not the fastest device when it comes to responding to image requests. Going down to 1 sec may be right on the edge of the response time from the image api (which is why I made it 2 seconds in the first place).
It might be better to use the mjpeg stream as @matt1 suggested above. While I havenât implemented that in the binding yet, you can access it using the following URL.
Hi, Iâm new to OpenHab. Can someone help me create the following rules?
The bell image should be updated when the bell is pressed.
If motion detection is active, the motion picture should be updated.
Does anyone have an example for me?
You shouldnât need a rule for this. The binding updates the doorbellImage channel when the doorbell is pressed, and it updates the motionImage channel when motion is detected.
Edit: You can verify that this is happening by observing the event log, which should show the item linked to the doorbellImage channel being updated whenever the doorbell is pressed.
