Got it working on Unifi USG by using the approach here: https://community.ui.com/questions/Multicast-Sonos-Phorus-and-Play-Fi-Broadcast-255-255-255-255-lessportgreater-Discovery-Solution/1ce890c2-5e7e-4ef2-a42a-e9c59444fd3f?page=5
Glad you got it sorted. Thanks for posting the solution.
This isnât strictly a question about the binding but I wondered if I could pick the brains of you clever Doorbird users out thereâŠ
Does anyone happen to know if the Doorbird D101 can supply an H.264 stream or does it always supply a series of MJPEG images? The reason I ask is that Iâm investigating moving from animated GIFs to H264 attachments sent via Telegram instead of Pushover when motion is detected at my front door. I have a Hikvision camera over the front door and a Doorbird doorbell and while I can get H264 streams from the Hikvision (as youâd expect) I canât seem to get anything but MJPEG from the Doorbird. Iâve tried VLC on Windows and Tinycam Pro on Android.
Not really a big deal but Iâm just curious if Iâm doing something wrong or itâs just not possible.
Yes, it does. See page 31 of the Doorbird API spec.
Have you ever got that rtsp URL to work in something like VLC? It never seems to work for me.
Not in VLC, but thatâs the URL I use in Zoneminder and it works great.
This is what I put in Zoneminder:
rtsp://<user>:<pass>@<ip>:8557/mpeg/media.amp
Make sure you give the user permission to use the API.
Strange, I use the same URL in my Zoneminder except I use port 554 rather than 8557 and it works fine (with the correct username/password), doesnât work in VLC though. Neither 554 nor 8557, Iâve checked that the user Iâm using has the API permission. Thanks for the tip!
I have a couple of Amazon Fire tablets around the house running Tinycam Pro that I use to monitor the house cams and if I cast my mind back to lasts year when I installed the Doorbird I had an issue using the URL on multiple devices so I used Zoneminder to serve the Doorbird stream onward. If I configured Tinycam to go direct to the Doorbird Iâd get something like 0.5fps. If I use Zoneminder as the Doorbird server I get around 8fps but itâs a JPEG stream so the datarate is around 500KBps compared to the other Hikvision cameras I have that run at around 10-20KBps.
Many thanks for your help and advice. Iâll keep investigating.
FWIW, Iâm not able to open the URL in VLC on my Mac. Older versions of VLC would just crash. The latest version of VLC just complains that the URL canât be opened.
In that case it looks like a VLC issue rather than a PEBKAC or Doorbird issue. Thanks for testing it, much appreciated! ![]()
first, good work!
â> Solved, see answer below
I installed the binding some time ago, and setup some rules, that send a REFRESH to the image channel to get the actually picture.
Sometimes it worked, and sometimes not, today I will figure out, why it happens, first I updated from openhab 2.5.10 to 2.5.11 and tried it again, after enable the Debug Log for this plugin I get an interesting information:
10:29:10.835 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Doorbell_Image' received command REFRESH
10:29:10.847 [DEBUG] [bird.internal.handler.DoorbellHandler] - Got command REFRESH for channel doorbird:d210x:doorbell:image of thing doorbird:d210x:doorbell
10:29:10.850 [DEBUG] [ing.doorbird.internal.api.DoorbirdAPI] - Downloading image from doorbird: http://192.168.0.169/bha-api/image.cgi
10:29:10.888 [DEBUG] [ing.doorbird.internal.api.DoorbirdAPI] - HTTP GET failed: 204, No Content
My Item:
Image Doorbell_Image "Doorbell Image [%s]" { channel="doorbird:d210x:doorbell:image" }
My thing:
Thing doorbird:d210x:doorbell âDoorbird D2102 Doorbellâ [doorbirdHost="192.168.0.169",userId="api_user",userPassword="api_password",doorbellOffDelay=3]
Doorbird model: DoorBird D2102V
Firmware Version: 128
EDIT:
Here is a full output of restart the bundle:
10:41:10.381 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'doorbird:d210x:doorbell' changed from ONLINE to UNINITIALIZED
10:41:10.400 [DEBUG] [internal.listener.DoorbirdUdpListener] - Listener got IOException waiting for datagram: Socket closed
10:41:10.400 [DEBUG] [internal.listener.DoorbirdUdpListener] - Listener exiting
10:41:10.401 [DEBUG] [internal.listener.DoorbirdUdpListener] - Listener closing listener socket
10:41:10.402 [DEBUG] [bird.internal.handler.DoorbellHandler] - Canceling listener job
10:41:10.419 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'doorbird:d210x:doorbell' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:41:10.527 [DEBUG] [nding.doorbird.action.DoorbirdActions] - DoorbirdActions service created
10:41:10.538 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'doorbird:d210x:doorbell' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
10:41:10.548 [DEBUG] [bird.internal.handler.DoorbellHandler] - Listener job is scheduled to start in 5 seconds
10:41:10.552 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'doorbird:d210x:doorbell' changed from INITIALIZING to ONLINE
10:41:10.553 [DEBUG] [bird.internal.handler.DoorbellHandler] - Got command REFRESH for channel doorbird:d210x:doorbell:doorbell of thing doorbird:d210x:doorbell
10:41:10.555 [DEBUG] [bird.internal.handler.DoorbellHandler] - Got command REFRESH for channel doorbird:d210x:doorbell:doorbellHistoryTimestamp of thing doorbird:d210x:doorbell
10:41:10.555 [DEBUG] [bird.internal.handler.DoorbellHandler] - Got command REFRESH for channel doorbird:d210x:doorbell:doorbellHistoryImage of thing doorbird:d210x:doorbell
10:41:10.556 [DEBUG] [bird.internal.handler.DoorbellHandler] - Got command REFRESH for channel doorbird:d210x:doorbell:openDoor1 of thing doorbird:d210x:doorbell
10:41:10.556 [DEBUG] [bird.internal.handler.DoorbellHandler] - Got command REFRESH for channel doorbird:d210x:doorbell:image of thing doorbird:d210x:doorbell
10:41:10.557 [DEBUG] [ing.doorbird.internal.api.DoorbirdAPI] - Downloading image from doorbird: http://192.168.0.169/bha-api/image.cgi
10:41:10.587 [DEBUG] [ing.doorbird.internal.api.DoorbirdAPI] - HTTP GET failed: 204, No Content
10:41:15.550 [DEBUG] [internal.listener.DoorbirdUdpListener] - Listener got UDP socket on port 6524 with timeout 3000
EDIT2:
I feel bad⊠After posting, I tried to read the api documentation from doorbird carefully, and by searching âbha-api/image.cgiâ I found:
When the request is correct, but the requesting user has no permission to view thelive image at the moment, the request is answered with return code 204. This usuallyhappens for users without âwatch-alwaysâ permission when there was no ring eventin the past 5 minutes
And the api user had no permission for live view, only for 5 minutes afters someone presses the buttonâŠ
Hi Guys
Starting to give OH3 a shot, what a nightmare ![]()
Anyway!
Seeing this error when I send a command to the relay, any suggetions?
06:52:38.953 [INFO ] [openhab.event.ItemCommandEvent ] - Item âDoorbird_OpenDoor1â received command ON
06:52:38.968 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method âThingHandler.handleCommand()â on âorg.openhab.binding.doorbird.internal.handler.DoorbellHandler@592d9389â: Illegal character in authority at index 7: http:// 192.168.0.141 /bha-api/open-door.cgi?r=1
java.lang.IllegalArgumentException: Illegal character in authority at index 7: http:// 192.168.0.141 /bha-api/open-door.cgi?r=1
at java.net.URI.create(URI.java:883) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:442) ~[bundleFile:9.4.20.v20190813]
at org.openhab.core.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:213) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:156) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:131) ~[?:?]
at org.openhab.core.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
at org.openhab.binding.doorbird.internal.api.DoorbirdAPI.executeGetRequest(DoorbirdAPI.java:248) ~[?:?]
at org.openhab.binding.doorbird.internal.api.DoorbirdAPI.openDoor(DoorbirdAPI.java:158) ~[?:?]
at org.openhab.binding.doorbird.internal.api.DoorbirdAPI.openDoorDoorbell(DoorbirdAPI.java:153) ~[?:?]
at org.openhab.binding.doorbird.internal.handler.DoorbellHandler.handleOpenDoor(DoorbellHandler.java:304) ~[?:?]
at org.openhab.binding.doorbird.internal.handler.DoorbellHandler.handleCommand(DoorbellHandler.java:197) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy330.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Caused by: java.net.URISyntaxException: Illegal character in authority at index 7: http:// 192.168.0.141 /bha-api/open-door.cgi?r=1
at java.net.URI$Parser.fail(URI.java:2913) ~[?:?]
at java.net.URI$Parser.parseAuthority(URI.java:3247) ~[?:?]
at java.net.URI$Parser.parseHierarchical(URI.java:3158) ~[?:?]
at java.net.URI$Parser.parse(URI.java:3114) ~[?:?]
at java.net.URI.(URI.java:600) ~[?:?]
at java.net.URI.create(URI.java:881) ~[?:?]
⊠29 more
06:52:38.976 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item âDoorbird_OpenDoor1â predicted to become ON
06:52:38.985 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âDoorbird_OpenDoor1â changed from NULL to ON
Cheers!
Thatâs a nasty looking error. Iâll see if I can reproduce.
It looks like thereâs a space before and after the IP address in the URL. I expect thatâs whatâs causing the problem. But I have no idea where those spaces are coming from.
Odd. I recreated it and its fine now!
Hello there!
I finally found some time for openhab again after we moved into our house.
now i am trying to play an alarm sound when the doorbell is triggered.
the rule works fine when i trigger it manually but i cannot get the âdoorbell pressedâ item to work.
I tried the pressed command as well as a simple trigger (received command on) as described in the docs.
after further investigation it seems that the item for the âdoorbell pressedâ switch does not work.
the thing is online and i can manually turn the light of the doorbird on so i am pretty sure itâs no âthingâ issue.
maybe my d1101v works different than the âoldâ doorbirds?
any suggestions what i could try?
i adapted the item config 1:1 from the docs âŠ
i also noticed that the âdoorbell pressed imageâ is very old (2 weeks or so). it seems that it does not get updated anymore and i donât know why.
the âlive imageâ however works fine.
thatâs also pointing to a âtriggerâ issue âŠ
By any chance is the Doorbird device on a different subnet than your openHAB box? If everything is set up correctly, this could be the issue.
Or, it could be a permissions issue. Check to make sure the Doorbird user youâve put in the Thing config has the correct permissions.
thank you!
i am running OH in docker so there is a high chance itâs a port issue.
I manually forwarded port 6524 now and will report back if i tested it.
That did the trick ![]()
Forwarding:
- 6524:6524/udp
thanks for pointing to that!
Any chance of support for keypad events?
A âworkaroundâ can be done with node-red.
You can create a http-Command with the specific/configured keypad input. The http-Command can be written directly to a node-red instance. There you can create a flow where you can write and read OpenHab items with the openhab-node.
Maybe I can give an example next week.
