So First question… Does anyone know how to set the ramp rate when sent from a z-wave command? The ramp rate from the switch itself gradually dims on where as if a command is sent to it it is instant. I want to be able have it so that when a command is sent it gradually turns on. All I can find is the local control ramp rate variables.
Also does anyone know if this is the exact same as the homeseer HS-WD100+ In my reading i found out that the HS-WD100+ is made by dragon Tech and appears to be identical less the homeseer (HS) labeling. If they are indeed the same can we incorporate the scene capability into openhab?
