Platform information:
Hardware: RPi-4B 4GB
OS: OpenHabian
Java Runtime Environment: which java platform is used and what version
openHAB version:3.1.0
Issue of the topic: Drayton Wiser Setup
Quick question… My OH3.1.0 install has picked up my Drayton Wiser. And I’ve added the token and comms are working fine apparently…
But there are no channels discovered… Do they discover? or is the channel config completely manual for the Wiser Binding?
rpwong
(Russ)
November 30, 2021, 11:21pm
#2
From a quick glance at the documentation, it looks like the Heat Hub is a bridge. So, I think you need to add individual things to control via the bridge, and those will give you the channels.
I re-read the docs a few times… And discovered half a sentence that I’d missed the first 20 times I read it…
Once the secret
has been configured, all other devices can be discovered by triggering device discovery again.
Counter intuitive, I expected all the other parts to pop up as channels. But I did a discovery and lo, I get lots more things in the inbox to add.
Which seems to work quite well. Except I can’t the HW controller yet. Maybe another scan…
Nope. I had to add the HW manually for some reason. But it does work…
