goodfore
(Goodfore)
August 27, 2017, 7:46am
1
HI @rsstephens and all,
Running in OH2 with Dscalarm 2.1. Once again, great work @rsstephens and thank you for maintaining the binding!
I have an item mapped to the partition arm mode channel:
Number Dsc_Partition_Arm_Mode "Partition Arm Mode: [%s]" {channel="dscalarm:partition:XXYYZZ:partition1:partition_arm_mode"}
When I do this in the sitemap:
Switch item=Dsc_Partition_Arm_Mode label="Alarm Arm Options:" icon="lock" mappings=[0="Disarm", 1="Away", 2="Stay"]
There is always the state displayed beside the buttons:
I remember in OH1, I did the same thing and there is no state showing. I tried in OH2 with another number item, and no state showing either.
I had to make a map and hide it like this:
Switch item=Dsc_Partition_Arm_Mode label="Alarm Arm Options:[MAP(number.map):%s]" icon="lock" mappings=[0="Disarm", 1="Away", 2="Stay"]
Just wondering if this is by design or a bug?
Thanks,
Joe
rlkoshak
(Rich Koshak)
August 27, 2017, 2:16pm
2
It is showing the state because you are telling it to in the label. The [%s] and [MAP(number.map):%s] are two ways one puts the Item’s state into the label.
Remove them and the state will go away.
goodfore
(Goodfore)
August 27, 2017, 3:19pm
3
If you look at my first sitemap, I don’t have %s nor map, yet it stills shows up.
Thanks,
Joe
rlkoshak
(Rich Koshak)
August 27, 2017, 11:03pm
4
what happens when you remove the [%s] from the item?
I vaguely remember a similar problem reported a while back but thought it was fixed. What version are you running?
goodfore
(Goodfore)
August 28, 2017, 4:18am
5
Just tried. Removing %s from item fixes it. So the issue is sitemap label not overriding item’s?
I am running 2.1.0 - release build -
Thanks,
Joe
rlkoshak
(Rich Koshak)
August 28, 2017, 5:46pm
6
Sounds like it and I bet if you upgraded to the 2.2 SNAPSHOT the error will go away. I’m 90% positive this has been fixed in the SNAPSHOT.
