I recently try to migrate OH from 2.5 to 4.3, and when I try to migrate the rule from file to UI-rule, I found issue with timer, after dig around I found privateCache, I’ll share here for anyone might interest.
Code in file
var Timer AlarmTempOffTimer = null
rule "Front Door Open closed"
Channel 'mqtt:topic:OpenHabSer:MiRemoteCube:Action' triggered
if(AlarmTempOffTimer === null) {
logInfo("Test", "Test about to start")
AlarmTempOffTimer =createTimer(now.plusSeconds(5), [|
logInfo("Test", "Timer Test for 5 Sec")])
else {
logInfo("Test", "Timer already set")
Code in UI-Rule
configuration: {}
triggers:
- id: "2"
configuration:
channelUID: mqtt:topic:OpenHabSer:MiRemoteCube:Action
type: core.ChannelEventTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/vnd.openhab.dsl.rule
script: >-
if(privateCache.get("AlarmTempOffTimer") === null) {
privateCache.put("AlarmTempOffTimer", createTimer(now.plusSeconds(5), [|
privateCache.put("AlarmTempOffTimer", null) // Reset the timer
} else {
type: script.ScriptAction
as you can see from the example,
privateCache.put(“AlarmTempOffTimer”, createTimer(…)) stores the timer in the cache.
privateCache.get(“AlarmTempOffTimer”) retrieves the timer from the cache.
hope can help anyone might get stuck with DSL
