I am trying to read the Belgium Smart meter (DSMR 5) via the Cedel Serial to USB.
The binding never comes online and I got this in the standard logs :
2022-10-23 14:28:50.252 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'dsmr:dsmrBridge:88dbeb9ec2' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-10-23 14:28:50.272 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'dsmr:dsmrBridge:88dbeb9ec2' changed from INITIALIZING to UNKNOWN
2022-10-23 14:29:26.824 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'dsmr:dsmrBridge:88dbeb9ec2' changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): Serial port does not exist.
2022-10-23 14:29:32.468 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'dsmr:dsmrBridge:88dbeb9ec2' changed from OFFLINE (CONFIGURATION_ERROR): Serial port does not exist. to UNKNOWN
2022-10-23 14:30:16.120 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'dsmr:dsmrBridge:88dbeb9ec2' changed from UNKNOWN to UNINITIALIZED
2022-10-23 14:30:16.162 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'dsmr:dsmrBridge:88dbeb9ec2' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-10-23 14:30:24.455 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'dsmr:dsmrBridge:88dbeb9ec2' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-10-23 14:30:24.483 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'dsmr:dsmrBridge:88dbeb9ec2' changed from INITIALIZING to UNKNOWN
and
2022-10-23 14:37:04.602 [WARN ] [device.connector.DSMRSerialConnector] - RuntimeException during handling serial event: 1
at org.openhab.binding.dsmr.internal.device.cosem.OBISIdentifier.<init>(OBISIdentifier.java:94) ~[bundleFile:?]
at org.openhab.binding.dsmr.internal.device.cosem.CosemObjectFactory.getCosemObject(CosemObjectFactory.java:87) ~[bundleFile:?]
at org.openhab.binding.dsmr.internal.device.p1telegram.P1TelegramParser.storeCurrentCosemObject(P1TelegramParser.java:405) ~[bundleFile:?]
at org.openhab.binding.dsmr.internal.device.p1telegram.P1TelegramParser.setState(P1TelegramParser.java:437) ~[bundleFile:?]
at org.openhab.binding.dsmr.internal.device.p1telegram.P1TelegramParser.parse(P1TelegramParser.java:234) ~[bundleFile:?]
at org.openhab.binding.dsmr.internal.device.DSMRTelegramListener.handleData(DSMRTelegramListener.java:74) ~[bundleFile:?]
at org.openhab.binding.dsmr.internal.device.connector.DSMRBaseConnector.handleDataAvailable(DSMRBaseConnector.java:116) ~[bundleFile:?]
at org.openhab.binding.dsmr.internal.device.connector.DSMRSerialConnector.handleDataAvailable(DSMRSerialConnector.java:317) ~[bundleFile:?]
at org.openhab.binding.dsmr.internal.device.connector.DSMRSerialConnector.serialEvent(DSMRSerialConnector.java:276) [bundleFile:?]
at org.openhab.core.io.transport.serial.rxtx.RxTxSerialPort$1.serialEvent(RxTxSerialPort.java:82) [bundleFile:?]
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:834) ~[bundleFile:5.2.1.OH1]
at gnu.io.RXTXPort.eventLoop(Native Method) [bundleFile:5.2.1.OH1]
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:108) [bundleFile:5.2.1.OH1]
I can read the information perfectly with screen /dev/ttyUSB0 115200
and via the serial binding on the same port.
DSMR Binding is version 3.3.0 on mint installed openhabian.
What did I miss ?
