im using now a p1 adapter for reading my smartmeter because the optical port is blocking reading by power company.
Now i have the problem if im scanning for my meter im seeing the following in log - but no usable channels:
2023-04-09 16:07:20.872 [INFO ] [.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object 'P1_VERSION_OUTPUT' found in the data: Cosem Object(type:P1_VERSION_OUTPUT, cosemValues:{=50})
2023-04-09 16:07:20.874 [INFO ] [.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object 'P1_TIMESTAMP' found in the data: Cosem Object(type:P1_TIMESTAMP, cosemValues:{=2023-04-09T16:06:47.000+0200})
2023-04-09 16:07:20.875 [INFO ] [.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object 'EMETER_EQUIPMENT_IDENTIFIER' found in the data: Cosem Object(type:EMETER_EQUIPMENT_IDENTIFIER, cosemValues:{=12345678})
2023-04-09 16:07:20.877 [INFO ] [.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object 'EMETER_DELIVERY_TARIFF1' found in the data: Cosem Object(type:EMETER_DELIVERY_TARIFF1, cosemValues:{=10386.411 kWh})
2023-04-09 16:07:20.878 [INFO ] [.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object 'EMETER_DELIVERY_TARIFF2' found in the data: Cosem Object(type:EMETER_DELIVERY_TARIFF2, cosemValues:{=7757.005 kWh})
2023-04-09 16:07:20.880 [INFO ] [.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object 'EMETER_PRODUCTION_TARIFF1' found in the data: Cosem Object(type:EMETER_PRODUCTION_TARIFF1, cosemValues:{=0.14 kWh})
2023-04-09 16:07:20.881 [INFO ] [.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object 'EMETER_PRODUCTION_TARIFF2' found in the data: Cosem Object(type:EMETER_PRODUCTION_TARIFF2, cosemValues:{=0 kWh})
2023-04-09 16:07:20.882 [INFO ] [.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object 'EMETER_ACTUAL_PRODUCTION' found in the data: Cosem Object(type:EMETER_ACTUAL_PRODUCTION, cosemValues:{=0 kW})
2023-04-09 16:07:20.883 [INFO ] [.discovery.DSMRMeterDiscoveryService] - There are unrecognized cosem values in the data received from the meter, which means some meters might not be detected. Please report your raw data as reference: /ELS5\@V10.04
1-3:0.2.8(50)
0-0:1.0.0(123456789S)
0-0:96.1.1(3230343238363835)
1-0:1.8.1(010386.411*kWh)
1-0:1.8.2(007757.005*kWh)
1-0:2.8.1(000000.140*kWh)
1-0:2.8.2(000000.000*kWh)
1-0:2.7.0(00.000*kW)
1-0:1.7.0()
!35A4
Someone has an idea how to get the channels and read the values in?
