Hi I’m new on openHab,
My mqtt Things, as well the opentherm Gateway are visible.
But I can’t find how I can connect my DSMR (P1) over an Ethernet connection.
On Home-assistance it works with the below settings,
I don’t think the binding supports serial over tcp/ip. I use a serial to usb (p1) cable. I assume you use an esp or equivalent to convert the P1 (serial) signal to tcp/ip?
If your OH is running on linux, maybe you can use socat? I have no experience with it but it looks quite easy:
OpenHab run’s in an Docker on a Linux host.
My P1 is connected trough an Ethernet Module USR-TCP232-T2 Ethernet Module USR-TCP232-T2
I’ve the same on on my Opentherm Gateway. And for this one I’ve a thing with the following in it.
Thing openthermgateway:otgw:1 [ ipaddress=“192.168.0.7”, port=23, connectionRetryInterval=60 ]
Is their an option to create a DSMR P1 connection in the Thing file as well?
