I’ve just installed OpenHAB and trying to connect my smart gateway but I am unable to and I don’t understand what I am doing wrong here (feel stupid!)
P1 port is open
I can see all the data via de Fluvius website
The smart gateway is connected and online via WiFi
Installed the DSMR binding
When I try to add Things, I see the binding, but when I click SCAN, OH does not find it.
If I want to add it manually I am a bit lost as it asks for a serial port, but the device is connected to my electricity meter and not to my RPI so there is something I am missing here.
If there are unexpected configuration issues. For example a meter could not be found or not all channels expected are available. Than run the discovery process and look into the log file. There are extra checks that can give more information about what might be wrong.
If this gateway works as a serial2net interface you should enter rfc2217://<ip of gateway>:<port> into the configuration of the serial port of the dsmr thing.
