DST bug fix in 2.3.0-SNAPSHOT
All,
I have just rolled out a new ESH stable build to the openHAB distro, which is included starting with distro build #1237.
Besides a couple of other fixes and improvements, it mainly contains a fix for the scheduler that is used in the Astro binding for Daylight Saving Time (DST) handling - without this fix, it is likely that the Astro binding will stop updating its values this Sunday until it is restarted. So if you are using the Astro binding and are on openHAB snapshot builds, you might want to update your system before Sunday!
Regards,
Kai
Link does not work, I guess it should be this one :sunglasses:
https://hudson.eclipse.org/smarthome/job/SmartHomeDistribution-Stable/260/changes
Great. For me it worked fine (see detailed report OpenHAB not saving mesaurements after daylight saving time change - #28 by cweitkamp).
