Dual Inverter Gauge Widget
I have this widget for monitoring dual Inverters.
Inverter1:
this inverter supplies power to the house and charges the batteries when there is needed power (not fulfilled by the second inverter)
Inverter2:
This inverter supplies what ever power that is needed to the house (based on what it can). This inverter has no connected batteries.
For reference (Top Level corner is an icon that shows Current to / from the batteries) and is a separate icon not related to the main Widget and only overlaid but I use for a quick reference if I am still charging the batteries during the course of the day.
Note: I have created the Version_ tag which I have the version number against my objects so enables me to see which version is in production.
Screenshots
Changelog
Version 1.1 First Release
Resources
uid: has_solar_consumption
tags:
  - has
  - version_1.1
props:
  parameters:
    - context: string
      default: The Name
      description: The name
      label: Name
      required: true
      type: TEXT
      groupName: Key
    - context: item
      description: The Main Inverter
      label: The Primary Inverter
      required: true
      type: TEXT
      groupName: Key
    - context: item
      description: The Secondary Inverter
      label: The Secondary Inverter
      required: false
      type: TEXT
      groupName: Key
    - context: string
      default: ""
      description: The Unit for the Above Fields
      label: The Unit
      required: false
      type: TEXT
      groupName: Key
    - context: number
      description: The min value Inverter 1
      label: Min
      required: false
      type: TEXT
      groupName: Key
    - context: number
      description: The max value Inverter 1
      label: Max
      required: false
      type: TEXT
      groupName: Key
    - context: number
      description: The min value Inverter 2
      label: Min
      required: false
      type: TEXT
      groupName: Key
    - context: number
      description: The max value Inverter 2
      label: Max
      required: false
      type: TEXT
      groupName: Key
    - context: string
      default: rgb(52, 235, 94,100%)
      description: Bottom 10% Color
      label: Bottom 10% Color
      required: true
      type: TEXT
      groupName: inverter1Colors
    - context: string
      description: Bottom 40% Color
      label: Bottom 40% Color
      required: true
      type: TEXT
    - context: string
      default: rgb(252, 200, 13,100%)
      description: Top 40% Color
      label: Top 40% Color
      required: true
      type: TEXT
    - context: string
      default: rgb(252, 52, 13,100%)
      description: Top 10% Color
      label: Top 10 Color
      required: true
      type: TEXT
    - context: string
      required: true
      type: TEXT
      groupName: inverter2Colors
    - context: string
      required: true
      type: TEXT
    - context: string
      required: true
      type: TEXT
    - context: string
      label: Top 10 Color
      required: true
      type: TEXT
    - context: number
      default: "10"
      description: The no of Splits
      label: The No of Splits
      required: true
      type: TEXT
      groupName: Sizes
    - context: number
      default: "5"
      required: true
      type: TEXT
      groupName: Sizes
    - context: number
      description: The height of widget
      label: Height
      required: false
      type: TEXT
      groupName: Sizes
    - context: string
      default: "#0c17eb"
      description: The Color of the Needle
      label: Needle Color
      required: true
      groupName: Colors
    - context: number
      default: "14"
      description: Font size for the Text
      label: Font Size
      required: false
      type: TEXT
      groupName: Fonts
    - default: rgb(250,39,7,0.70)
      description: Background Color Consume
      label: The color of the Background
      required: false
      type: TEXT
      groupName: Colors
    - default: rgb(111,179,8,0.70)
      description: Background Color Charge
      required: false
      type: TEXT
      groupName: Colors
    - default: "120"
      description: Background Size
      label: The Size of the Background
      required: false
      groupName: Background
    - default: "false"
      description: Show the Chart Background
      label: true/false
      required: false
    - context: string
      default: black
      description: axisColor
      label: The Axis Color
      required: false
      type: TEXT
  parameterGroups:
    - name: Key
      context: Key
      label: Key
      description: The most Important Items
    - name: Colors
      context: Colors
      label: Colors
      description: Change the Colors
    - name: inverter1Colors
      context: Colors
      label: Colors
      description: Change the Colors for Inverter 1
    - name: inverter2Colors
      context: Colors
      label: Colors
      description: Change the Colors for Inverter 2
    - name: Fonts
      context: Fonts
      label: Fonts
      description: Change Fonts
    - name: Sizes
      context: Sizes
      label: Sizes
      description: Change Sizes of graph
    - name: Background
      context: Background
      label: Background
      description: Control the Background
timestamp: Jan 13, 2025, 8:45:22 PM
component: oh-chart
  height: =props.height
slots:
  series:
    - component: oh-data-series
        anchor:
          show: false
        axisLabel:
          color: =props.axisColor
          distance: -10
          show: true
        axisLine:
          lineStyle:
            color:
              - - 0.1
                - =props.i1_1Color
              - - 0.5
                - =props.i1_2Color
              - - 0.9
                - =props.i1_3Color
              - - 1
                - =props.i1_4Color
            width: 5
          show: true
        axisTick:
          distance: -45
          lineStyle:
            color: "#999"
            width: 2
          show: false
          splitNumber: 5
        center:
          - 50%
          - 60%
        data:
          - value: =#[props.inverter1]
        detail:
          borderRadius: 8
          color: inherit
          lineHeight: 40
          offsetCenter:
            - 0
            - -15%
          show: false
          valueAnimation: true
          width: 60%
        endAngle: -20
        itemStyle:
          color: '= (#[props.inverter1]/props.i1max < 0.9 ? "rgb(52, 235, 94,60%)" :
            "green" )'
          show: false
        max: =props.i1_max || 100
        min: =props.i1_min || 0
        pointer:
          icon: path://M2090.36389,615.30999 L2090.36389,615.30999 C2091.48372,615.30999
            2092.40383,616.194028 2092.44859,617.312956 L2096.90698,728.755929
            C2097.05155,732.369577 2094.2393,735.416212 2090.62566,735.56078
            C2090.53845,735.564269 2090.45117,735.566014 2090.36389,735.566014
            L2090.36389,735.566014 C2086.74736,735.566014 2083.81557,732.63423
            2083.81557,729.017692 C2083.81557,728.930412 2083.81732,728.84314
            2083.82081,728.755929 L2088.2792,617.312956 C2088.32396,616.194028
            2089.24407,615.30999 2090.36389,615.30999 Z
          itemStyle:
            color: =props.needleColor
          length: 115%
          offsetCenter:
            - 0
            - 15%
          show: false
        progress:
          show: false
          width: 40
        radius: 92%
        splitLine:
          distance: -38
          length: 14
          lineStyle:
            color: "#999"
            width: 3
          show: false
        splitNumber: =props.splitNo1
        startAngle: 200
        title:
          offsetCenter:
            - - null
            - -50%
          show: false
        type: gauge
        axisLabel:
          show: false
        axisLine:
          lineStyle:
            width: 10
          show: false
        axisTick:
          distance: -45
          lineStyle:
            color: "#999"
            width: 2
          show: false
          splitNumber: 5
        center:
          - 50%
          - 60%
        data:
        detail:
          borderRadius: 8
          formatter: = @[props.inverter1] + props.myUnit
          lineHeight: 40
          offsetCenter:
            - 0
            - -9%
          width: 60%
        endAngle: -20
        itemStyle:
          color: "=(#[props.inverter1]/props.i1_max < 0.1)? props.i1_1Color
            :(#[props.inverter1]/props.i1_max < 0.5)?
            props.i1_1Color:(#[props.inverter1]/props.i1_max < 0.9)?
            props.i1_3Color : props.i1_4Color"
        pointer:
          itemStyle:
          length: 115%
          offsetCenter:
            - 0
            - 15%
          show: false
        progress:
          show: true
          width: 20
        radius: 95%
        splitLine:
          distance: -38
          length: 14
          lineStyle:
            color: "#999"
            width: 3
          show: false
        startAngle: 200
        title:
          offsetCenter:
            - - null
            - -50%
        type: gauge
        axisLabel:
          distance: 50
          show: true
        axisLine:
          lineStyle:
            color:
              - - 0.1
                - =props.i2_1Color
              - - 0.5
                - =props.i2_2Color
              - - 0.9
                - =props.i2_3Color
              - - 1
                - =props.i2_4Color
            width: 5
          show: true
        axisTick:
          distance: -45
          lineStyle:
            color: "#999"
            width: 2
          show: false
          splitNumber: 5
        center:
          - 50%
          - 60%
        data:
          - value: =#[props.inverter2]
        detail:
          borderRadius: 8
          color: inherit
          lineHeight: 40
          offsetCenter:
            - 0
            - -15%
          show: false
          width: 60%
        endAngle: -20
        itemStyle:
          show: false
        max: =props.i2_max || 100
        min: =props.i2_min || 0
        pointer:
          itemStyle:
          length: 115%
          offsetCenter:
            - 0
            - 15%
          show: false
        progress:
          show: false
          width: 40
        radiusx: 88%
        splitLine:
          distance: -38
          length: 14
          lineStyle:
            color: "#999"
            width: 3
          show: false
        splitNumber: =props.splitNo2
        startAngle: 200
        title:
          offsetCenter:
            - - null
            - -50%
          show: false
        type: gauge
        axisLabel:
          show: false
        axisLine:
          lineStyle:
            width: 10
          show: false
        axisTick:
          distance: -45
          lineStyle:
            color: "#999"
            width: 2
          show: false
          splitNumber: 5
        center:
          - 50%
          - 60%
        data:
        detail:
          borderRadius: 8
          formatter: = @[props.inverter2] + props.myUnit
          lineHeight: 20
          offsetCenter:
            - 0
            - 19%
          width: 60%
        endAngle: -20
        itemStyle:
          color: "=(#[props.inverter2]/props.i2_max < 0.1)? props.i2_1Color
            :(#[props.inverter2]/props.i2_max < 0.5)?
            props.i2_1Color:(#[props.inverter2]/props.i2_max < 0.9)?
            props.i2_3Color : props.i2_4Color"
        pointer:
          itemStyle:
          length: 115%
          offsetCenter:
            - 0
            - 15%
          show: false
        progress:
          show: true
          width: 15
        radius: 78%
        splitLine:
          distance: -38
          length: 14
          lineStyle:
            color: "#999"
            width: 3
          show: false
        startAngle: 200
        title:
          offsetCenter:
            - - null
            - -50%
        type: gauge
