Dual persistence problem/question
I have two persistence services running:
  • influxdb (for use with grafana) (default)
  • mysql
The default is set to influxdb (in paperui) but I also want to store some (string) data using the mysql persistence.
In the mysql.persist I’ve setup a strategy to store the data on everyUpdate, checking the sql database I see the correct data is stored, so no worries about that part.
However when executing a rule, it doesn’t find the item I try to use :
Error during the execution of rule test: cannot invoke method public java
.lang.String org.joda.time.base.AbstractInstant.toString() on null
It looks like the rule checks the (default) influxdb database rather then mysql database.
How can I let my rule know that it needs to ‘get’ the item from mysql ?
-ben
Could you post more of the Log?
I think I found the solution on Persistence · openhab/openhab1-addons Wiki · GitHub
These extensions use the default persistence service that is configured
in openhab.cfg. If the default service should not be used, all
extensions accept a String as a further parameter for the persistence
service to use (e.g. "rrd4j" or "sense").
Where do I add which persistence service to use ?
-ben
https://puu.sh/vGqqH/5ab3c3bc5b.png
Is this whats you`r looking for?
Thanks for you ‘support’ but this is not what I was looking for.
After carefully reading the lines again, this solved it :
if (Light1.updatedSince(now.minusSeconds(90),"mysql") == false ) {    // more then 90 seconds ago
        logInfo("Light", "offline")
Added the “mysql” line with comma.
Thanks everyone with suggestions!
-ben
