I suspect that some things either by the binding got duplicated or the paperUI. I normally just use the paperUI to install addons(maybe I am old fashioned, or frustrated that paper Ui does not modify/update or create .items file but rather json files and then you add up with both json and .items file that you need to keep track off )
I got this warning now:
2018-11-04 23:19:57.532 [WARN ] [ore.common.registry.AbstractRegistry] - GroupItem with key 'Alexa_Kitchen' already exists from provider GenericItemProvider! Failed to add a second with the same UID from provider GenericItemProvider!
2018-11-04 23:19:57.593 [WARN ] [ore.common.registry.AbstractRegistry] - GroupItem with key 'Alexa_Bathroom' already exists from provider GenericItemProvider! Failed to add a second with the same UID from provider GenericItemProvider!
2018-11-04 23:19:57.887 [WARN ] [ore.co
How can I get rid of this warning?
