For the dutch people, living in the area where AVRI comes to get the garbage, I’ve create a simple rule to show when to get the garbage outside.
It’s done with Ephemeris action.
The XML file is based on my location:
<?xml version="1.0" encoding="UTF-8"?>
<tns:Configuration hierarchy="nl" description="Afval kalender" xmlns:tns="http://www.example.org/Holiday" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.example.org/Holiday /Holiday.xsd">
<tns:Holidays>
<tns:FixedWeekday which="SECOND" weekday="TUESDAY" month="JANUARY" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="LAST" weekday="TUESDAY" month="JANUARY" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="THIRD" weekday="TUESDAY" month="FEBRUARY" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="SECOND" weekday="TUESDAY" month="MARCH" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="FIRST" weekday="TUESDAY" month="APRIL" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="FOURTH" weekday="TUESDAY" month="APRIL" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="THIRD" weekday="TUESDAY" month="MAY" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="FIRST" weekday="TUESDAY" month="JUNE" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="FOURTH" weekday="TUESDAY" month="JUNE" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="THIRD" weekday="TUESDAY" month="JULY" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="FIRST" weekday="TUESDAY" month="AUGUST" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="FOURTH" weekday="TUESDAY" month="AUGUST" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="THIRD" weekday="TUESDAY" month="SEPTEMBER" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="SECOND" weekday="TUESDAY" month="OCTOBER" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="LAST" weekday="TUESDAY" month="OCTOBER" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="THIRD" weekday="TUESDAY" month="NOVEMBER" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="SECOND" weekday="TUESDAY" month="DECEMBER" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="LAST" weekday="TUESDAY" month="DECEMBER" descriptionPropertiesKey="PLASTIC"/>
<tns:FixedWeekday which="SECOND" weekday="THURSDAY" month="JANUARY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FOURTH" weekday="THURSDAY" month="JANUARY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FIRST" weekday="THURSDAY" month="FEBRUARY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="THIRD" weekday="THURSDAY" month="FEBRUARY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FIRST" weekday="THURSDAY" month="MARCH" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="THIRD" weekday="THURSDAY" month="MARCH" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FIRST" weekday="THURSDAY" month="APRIL" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="THIRD" weekday="THURSDAY" month="APRIL" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FIRST" weekday="THURSDAY" month="MAY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="THIRD" weekday="THURSDAY" month="MAY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="LAST" weekday="THURSDAY" month="MAY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="SECOND" weekday="THURSDAY" month="JUNE" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FOURTH" weekday="THURSDAY" month="JUNE" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="SECOND" weekday="THURSDAY" month="JULY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FOURTH" weekday="THURSDAY" month="JULY" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FIRST" weekday="THURSDAY" month="AUGUST" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="THIRD" weekday="THURSDAY" month="AUGUST" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FIRST" weekday="THURSDAY" month="SEPTEMBER" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="THIRD" weekday="THURSDAY" month="SEPTEMBER" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FIRST" weekday="THURSDAY" month="OCTOBER" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="THIRD" weekday="THURSDAY" month="OCTOBER" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="LAST" weekday="THURSDAY" month="OCTOBER" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="SECOND" weekday="THURSDAY" month="NOVEMBER" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="FOURTH" weekday="THURSDAY" month="NOVEMBER" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="SECOND" weekday="THURSDAY" month="DECEMBER" descriptionPropertiesKey="GFT"/>
<tns:FixedWeekday which="THIRD" weekday="SATURDAY" month="DECEMBER" descriptionPropertiesKey="GFT"/>
</tns:Holidays>
</tns:Configuration>
Items:
String GFT "Wanneer moet GFT aan de weg? [%s]" <calendar> (Home, RestoreOnStartup)
String PLASTIC "Wanneer moet Plastic aan de weg? [%s]" <calendar> (Home, RestoreOnStartup)
Rule:
rule "Afval aan de weg"
System started
or
Time is midnight
val Gdays = Ephemeris.getDaysUntil("GFT","/etc/openhab2/services/garbage.xml")
val Pdays = Ephemeris.getDaysUntil("Plastic","/etc/openhab2/services/garbage.xml")
val Gstring =
if (Gdays >1){
"Over "+Gdays+" dagen"
}else{
if (Gdays == 1){
"Morgen"
}else {
"Vandaag"
val Pstring =
if (Pdays >1){
}else{
if (Pdays == 1){
"Morgen"
}else {
"Vandaag"
PLASTIC.postUpdate(Pstring)
GFT.postUpdate(Gstring)
You’ve to change the XML file according to your schedule. Use mine as an example. The location of the file is $OHCONFIG/services. You’ve to change it in the rule, based on your system (linux, windows, etc).
