Dynamic custom icons in HABpanel not working
got my OpenHAB 2.5 installation up and running, now I am trying to use custom dynamic icons.
I have a Contact entry in homematic.items:
Contact Wetterstation_aussen "Wetterstation Batteriestatus [MAP(de.map):%s]" <WetterstationBatterie> {channel="homematic:HG-HM-WDS10-TH-O:ccu:OEQ1296638:0#STATE", autoupdate="true"}
custom icons are in /etc/openhab2/icons/classic:
WetterstationBatterie.svg
WetterstationBatterie-on.svg
WetterstationBatterie-off.svg
Also tried a custom widget:
<widget-icon iconset="stefans_icons" icon="WetterstationBatterie" size="50"></widget-icon>
This screenshot shows my dummy widget settings when entering the text for the .svg icon (sorry in german, but I think you know the menu):
As you can see, the image next to the icon Name “WetterstationBatterie” is not showing a battery symbol and when I click “show image” I get the following error:
HTTP ERROR 404
Problem accessing /icon/WetterstationBatterie. Reason:
Not Found
What is wrong ?
OK, regarding to the docu I have to use a Switch and a String value in homematic.items file, her my try:
Switch Wetterstation_Batterie "Wetterstation Batterie Status" <WetterstationBatterie>
String Wetterstation_Batterie_Connection "Wetterstation Batterie [MAP(error.map):%s]" <myerror>
But I am not sure if I have to use this syntax as the paper UI already has all switches defined. In Paper UI the item is called
homematic_HG_HM_WDS10_TH_O_b09eabc7_OEQ1296638_0_LOWBAT
That’s the reason for using a Contact entry. But also, in the Contact entry I use a homematic channel, no idea if that is good. Help is appreciated.
Was right according to the docu, I need to add the channel to the switch:
Switch  WetterstationBatterie   "Wetterstation Batteriestatus" <WetterstationBatterie> {channel="homematic:HG-HM-WDS10-TH-O:b09eabc7:OEQ1296638:0#LOWBAT"}
String WetterstationBatterie_Connection "Wetterstation Batteriestatus [MAP(de.map):%s]" <myerror>
I have a myerror.svg icon now also.
So is that right ?
I think you put your icons in the wrong folder. The “icons/classic” should be in the config folder.
Edit: The “on”/“off” part in the icon resembles the state of the item it is used for. If you want to use it for a contact you have to use “open” and “closed”.
Well that’s the big problem for me: where is the config folder ? Is it /etc/openhab2 or /var/lib/openhab2 or even /var/lib/openhab2/config ?
I tried all 3, copying the icons/classic folder with the files, no success.
History: I used a raspbian buster image from last years semptember, updated all packages, installed homegear and openhab2 through “apt install”. The packages were updated in the meantime multiple times. Should be a straight forward installation.
To be save I now have on/off and open/closed state icons.
It’s exactly where your put you items-files. Have a look at openHAB on Linux | openHAB.
Yep, I read that docu before and put the svg-icons into /etc/openhab2/icons/classic, but weird it’s not working.
Maybe the permissions are wrong on the folder.
/etc/openhab2/icons and /etc/openhab2/icons/classic have owner:group openhab:openhab and permissions chmod 755, files have same owner:group and chmod 644.
Does it work in BasicUI?
Couldn’t test it with Basic UI, but with Classic UI. There it worked as soon as I renamed the WetterstationBatterie.svg to battery.svg, same with the on/off icons.
Then I removed the custom widget and the homematic.items file and it works in HABpanel as well.
So you have the following item:
When you name the icon “battery.svg” it is working? I don’t see how. Your icon should be named “WetterstationBatterie.svg” (the same name as in the item definition). Are you sure you don’t have defined the same item somwhere else with a different icon (e.g. in PaperUI)? Check your logs if there are entries/errors when you change your item-file (at least there should be an entry that it is reloaded).
Edit: Maybe try doing all in lowercase and name it “wetterstationbatterie.svg” (also in the item definition)
I know what you are saying, but it only works with battery as custom icon name:
It shows the icons I copied from this openhab2 web page.
I will check with “wetterstationbatterie.svg” and other situations later today.
Sorry, i missunderstood you. I thought your custom-icon was working with “battery”. With the default-icons it is working. For me it also works with custom-icons (also dynamic ones).
But battery.svg is in the standard icon set
Yes true, but they don’t work the same way. I just selected the eclipse battery icon and it shows a different battery icon for the current state. I believe they don’t work for dynamic icons. Do they ?
They actually do work the same way. I con confirm that dynamic-icons are working in HABPanel. I did it the same way you described it, so I assume you did something wrong. With the informations you gave until now I can’t tell you what is wrong. So please have a look at your log-files.
It’s working now, even though I had to use a proxy item for the humidity as it is bugged (see forum posts).
It worked as soon as I installed the Classic UI in addition to the HABpanel, only then the classic icons were available. But custom icons work also.
