I’m trying to get dynamic icons working correctly for the “Condition” value returned by the weather binding.
I’ve specified the icon as condition and in icons/classic I have a “condition.svg” and a bunch of others for specific values. “condition-clear.svg” or “condition-overcast.svg” will work and get correctly used for “Clear” or “Overcast” condition values, but “condition-partly_cloudy.svg” will not get used for “Partly Cloudy”. In that case, I just get the default “condition.svg” icon.
I have not been able to find the proper syntax documented anywhere. From what I’d read, I thought a space in the string would get mapped to an underscore in the file name but that doesn’t work. There are a very large number of possibly conditions returned by the weather binding and most of them have spaces.
Hmm…if all else fails, you could try creating a helper (or proxy) item and use that on the sitemap.
Whenever the “real” weather item changes, via a rule set the helper item to the same string but with the space replaced with “_”. Assign the icon to that Item and you icons should work.
It’s cracking nuts with a sledgehammer, but it should work.
Spaces in icon names might well lead to inconsistencies trying to retrieve/display in different UI environments.
There was an issue raised and dealt with for spaces in the “main” part of teh icon name some years ago. That would not help with spaces in the “after-hyphen” dynamic selection part though, I think
