I`m organizing my Sitemap to a new Order and wanted to use some indiviudual Icons.
Is there a possibility i can use different icons i relation to the State ?
Example:
Light On= Icon Green Bulb
Light Off= Icon Red Bulb ?
The Items from Basic UI are already changing - but how can i use “my own” icons in a dynamic mode ?
Thank you for your help
But i got anoter problem
When using png files - i can see the icons on my iphone but not on my android devices or my webbrowser…
when i use svg files - i see the icons on my webbrowser and android devices, but not on my iphone…
Can someone explain what is happening ?
//solved this Problem
just set in paperui/config/services/ui => default PNG
that`s it
I don’t know about the iPhone app but in the android app there is a option in the Display Section to choose which icon format to use: Vector (svg) or Bitmap (png)
The same option is available in the paperUI for the UI.
Go to Configuration - Services - UI - Classic UI - Configure
and choose the icon format
Same goes for Basic UI
