- Platform information:
- Hardware: RPI5
- OS: Debian
- Java Runtime Environment: 17.0.14
- openHAB version: 4.3.4
Hi All,
I am trying to create a set of new items dynamically via rule, I already saw this post, and thought it would be fairly simple, but can’t get it to work.
As I suspect Rik is going to ask: why?
What I want to do is produce a chart showing the sunrise over time in a curve using the Openhab charts.
As you can see, I have already done it for sunrise, but now I wanted to add all the other astro events to the same chart.
To get Openhab to do all the DB persistence and charting, I need to create an item for each event - I know I can manually create 20 events, and be done with it, but I thought it would be nice to make this fully automatic.
Here is my code:
function getEvents(sunEvent, sItem, sStart){
var sunActions = actions.Things.getActions("astro","astro:sun:mylocation");
if(null === sunActions) {
console.log("actions: sunActions not found, check thing ID");
} else {
var oItem = items.getItem(sItem);
if (oItem == null) {
console.log("Creating new item:" + sItem);
//var StringItem temporaryItem = (new StringItem(UUID.randomUUID().toString()));
//temporaryItem.label = sItem;
// First, purge all existing persisted entries
items.getItem(sItem).persistence.removeAllStatesBetween(time.ZonedDateTime.now().minusYears(1) ,time.ZonedDateTime.now().plusYears(1), 'jdbc');
// Parse through every day, work out the start time of sunrise in decimals and persist it to the DB
for (var i = -360; i <= 360; i++) {
var today = time.ZonedDateTime.now().plusDays(i);
var sunEventTime = sunActions.getEventTime(sunEvent,today,sStart);
var eventTime = (sunEventTime);
var sTime = eventTime.toString();
//2025-06-08T05:42+02:00
var iHours = parseFloat(sTime.slice(11, 13));
var iMins = parseFloat(sTime.slice(14, 16)/60)
var nNewTime = (iHours+iMins).toFixed(2);
console.log("AstroActions: "+sunEvent+" will happen at ", nNewTime);
items.getItem(sItem).persistence.persist(today, nNewTime, 'jdbc');
getEvents("SUN_RISE","AstroSunriseStart", "START");
The 2 lines commented out just don’t work, they give this error:
Also, I suspect I need to create a numeric item, would this be?:
var NumericItem temporaryItem = (new NumericItem(UUID.randomUUID().toString()));
Any tips?
Thanks in advance
Will
