Dyson fan integration into current openHAB
Hi all
I try to integrate my Dyson fans into openHAB 4.3.5.
The only articles I found are pointing to older openHAB versions.
Does anyone have a running integration of Dyson fans into openHAB 4.3.5 and is willing to guide me?
René
I followed this years back and it still works on OH5M2..
Hi Ole
I’ll try to implement this next week. I let you know if anything worked fine.
Thanks so far
René
Hi Ole
I tried to implement your script. The prepare-script went fine so far, I copied the items and things file and found the Broker and Thing in the Things. I used the values from the label sticker.
But the Broker won’t go online - Error with: Connection refused
I then tried to connect the same way with the MQTT Explorer, but was as well not successful.
I took the UID and PW from the broker-file.
Do you have any ideas what I can check more?
René
