since shortly I get en error when trying to edit Z-wave things in PaperUI. I tried for more than one thing and both in Chrome and Edge I get the following error:
E500 - Internal Server Error
I’m not so familiar with HABMIN but when I try to enable “show advanced settings” I don’t get an error but nothing changes…in other words also in HABMIN I’m not able to check settings like polling.
This is my current setup
Rasp Pi 3 Model B with Buster
OPENHAB 2.5.0-1
Only one binding in use : Zwave 2.5.0
I cannot be sure as of when I’m having this issue I’m 100% positive that it all worked fine a couple of weeks ago. Also all the rest seems to be working well.
I upgraded from Openhab 2.4 to 2.5 a couple of days ago.. Again, no way for me to say that this is the rootcause of the issue but it could be the case.
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
I just did a new stop/start openhab2 to obtain a clean log: this is the result
2020-01-08 19:47:57.399 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.zwave [23]
Unresolved requirement: Import-Package: org.eclipse.smarthome.io.transport.serial
2020-01-08 19:48:07.487 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar
