Easee bindinghannel
In the Equalizer are a few impotent settings.
  1. Activating the Equalizer. This means when active load restrictions kick in (Charge limited; Inside this setting you can select the base A). With this setting it will always charge at the limited configured A (default is 6A) and it will charge more if there is enough solar energie available.
  2. Charge only when enough (more than 6A) solar energy available).
    Inside option 1 is the limited A setting not so important but the other 3 are (Activating the equalizer and selecting the options reduced charging or only charging on solar.
Other question. What is this channel doing?
{channel="easee:mastercharger:762a1d9fc8:EUQFCLGS:state#smartCharging"}
PS Binding is working fine. Thanks.
