What is the easiest way to link to channels, so that changes of Item A get reflected to Item B? For example I have a light switch that has a status LED and would like to link it to the light that it switches. I am using 2 Items there to keep my items file more clean, I could of course directly connect it to the main channel but this keeps my configuration simpler as I have the switches in a seperate file.
Of course I found (Why) is linking two items complex? already, which uses rules (and that would have been my first approach aswell), is there a simpler way to do it though, if I remember correctly I read about a "bind"or link binding a while ago?
It’s probably worth clarifying that you are talking about linking two devices, rather than just two OH Items.
If these devices are compatible technology e.g. both zwave or both KNX it is invariably better to link them directly, and just let OH eavesdrop on the action. But of course that is not always possible.
This thread has a fairly extensive explore of using follow profile and possible pitfalls.
