Easiest way to swap leading sign of item value?
Hi all,
looking for an easy solution to swap +/- resp. positive to negativ and vice versa for an Item value, polled every 5sec by modbus.
Kind of like a “scale” value * -1 … ?
Cheers
Consider reading about link profiles :wink:
E.g.:
When/where do you want to do this? Before the state gets to the Item? In a Rule? Just for display?
If before the state gets to the Item @curlyel’s link is the best and easiest choice. But if in other places you’ll need something besides a profile.
Thanks, perfect, exactly what I did look for:
The values of QuantityType, PercentType and DecimalTypes are negated (multiplied by -1). Otherwise the following mapping is used:
Works direktly like charm :slightly_smiling_face:
Albeit using various transformations, never realized that basic-profiles. Obviously too much trees in the forest … :sweat_smile:
