I am just migrating from domoticz to openhab and am failing miserably creating any rules.
I created a number item with 8 values.
I can see in the logs that when i change the item it says item xxx received command 1-8 depending on what i select.
Now I would like to create an easy rule to switch on some power item when a certain value is reached.
But I cannot seem to get the format right. Can someone point me in the right direction?
I’m not sure you’ve yet grasped the essential difference between commands (“do something”, instruction) and state (“its like this”, information).
You certainly can trigger a rule from a command, which usually comes from user clicking or from another rule.
But that doesn’t seem to relate to your objective “when a certain value is reached”. Is that certain something a sensor, should you be triggering from changes to that?
