sorry but I need much more details. Could you please set the logging to debug and restart openhab and send me the log from start until your polling command +10 seconds. And you configuration file is not complete, could also add the complete file.
Another question, the binding is working fine with the build-in configuration ?
You can send the file via PM or email to
oh (-@-) cs-dev . de
%.1f°C is not giving results like 21,1°C but 21,245 and no units notificaiton. This is only issue with one temperature SP1 from VR68
Same formula in SP2 is giving proper value
With custom file “automatic inbox detection is not working”
You can only set this in paper ui at the moment. If you edit a thing you see some edit icons on some value. You can set the polling there. All values of a group will be refreshed on polling. So only one polling per group is required.
I thing this is a standard behavior of openhab 2.x. It looks like the formatter is only for paper ui and not for basic ui.
I’m sure that the the identification byte array is wrong. You can now check this with the new console command smarthome:ebus devices <bridgeId> . It should show you all devices with the device id.
Do you work with alpha 10? Can you see the command if you enter help ? Is smarthome:ebus list working?
Maybe the syntax is smarthome ebus ... if you not use the Karaf console. This happend here in my development environment.
I started tests with Alpha 10 just recently and it seems it fixed (at least partially) my problem with own parsers.
Why I say partially because e.g. heating hours are read but time or system pressure is not (and I don’t know if it’s formatting issue or binding issue). Since csowada checked it at home (without the real device) and it worked this suggests format of parsers to be correct but I don’t know.
second question - how to find 5 magic bytes for VR68/4 ? from ebusd it seems address if 50 (I guess slave, then master should be 45 following the ‘difference pattern’). I want to add parser for it and see whether that would work and then collect debug and send all together to understand what’s wrong with my parsers
@Kristo do I get properly that this magic is for autodiscovery only, in other words if I know addresses and enter them manually, I can skip these bytes in the json file?
If you have a complete telegram from any log or your own device you can use the command line to test you custom parser without sending it. It’s a small tool to analyze telegrams.
can you help me to start with VR61 parsers? I tried to get Heating Curve 2 from it (it should be there as I have 2 circuits and it’s visible via VRC) but getting 0.0
I simply copied curve parser from HC1 prepared by @csowada for VRC, so should be good. Address I used is 50 for slave (and so far it was a rule that master=slave -5 so I took 50/45). I also took command 0D 15 00 or 0E respectively. Polling works but don’t get results into my items
