Hello @csowada,
I started experimenting with your ebus 2 binding. It is great.
Thank you for all your work end efforts.![]()
I have a question on the integration of external json configuration files.
In my setup I run a Vaillant ecoCOMPACT VSC 196 with an external VR61 mixer module to drive a sendoc heating circuit for a low temperature underfloor heating.
I am connected to the eBus via Esera USB coupler. I can successfully get and control the Vaillant VRC 430 and the BAI00 standard parameter.
What is completely missing is the VR61 part and all my attempts to include were unfortunately without success.
From my understanding VR61 is not provided in the standard config scope of your latest binding.
So I downloaded the VR61 config which I felt appropriate from you github store:
and linked the file in the config in the binding configuration:
This is my installed version:
openhab> feature:list | grep eBUS
ebus-binding x 2.4.0.RC4 x x x Started x ebus-distro-2.4.0.RC4 x eBUS 2.0 binding incl. eBUS core libs
My edvices:
openhab> smarthome:ebus devices
MA | SA | Identifier | Device | Manufacture | ID | Firmware | Hardware | Last Activity
FF | 04 | | <interface> | eBUS Library | | null | null | ---
| 50 | 56 36 31 30 30 | --- | Joh. Vaillant GmbH & Co. | B5 | 1.19 | 19.02 | Mon Mar 18 20:17:14 CET 2019
3F | 44 | | --- | null | | null | null | Mon Mar 18 18:17:57 CET 2019
10 | 15 | 34 33 30 30 30 | vrc430 | Joh. Vaillant GmbH & Co. | B5 | 2.15 | 20.02 | Mon Mar 18 20:17:14 CET 2019
03 | 08 | 42 41 49 30 30 | bai | Joh. Vaillant GmbH & Co. | B5 | 5.18 | 74.01 | Mon Mar 18 20:17:11 CET 2019
MA = Master Address / SA = Slave Address / ID = Manufacture ID
The bridge statistics:
an the last portion of the ebus-unresolved.csv file from today:
2019-03-18 20:14:24;"10";"50";"B5 05";"02 18 00 34 00 00 00";
2019-03-18 20:14:25;"10";"50";"B5 05";"02 30 01 48 00 01 01 9A 00";
2019-03-18 20:14:27;"10";"50";"B5 03";"02 00 01 41 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:14:31;"10";"50";"B5 04";"01 18 E7 00 06 31 31 00 99 02 18 C1 00";
2019-03-18 20:14:33;"10";"50";"B5 04";"01 26 D9 00 07 02 02 00 30 01 CB 01 11 00";
2019-03-18 20:14:34;"10";"50";"B5 03";"02 00 03 43 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:14:34;"10";"50";"B5 09";"04 0E 01 00 01 55 00 00 00";
2019-03-18 20:14:34;"10";"50";"B5 09";"04 0E 20 00 01 2E 00 00 00";
2019-03-18 20:14:34;"10";"08";"B5 10";"09 00 00 62 46 FF FF 00 FF 00 48 00 01 01 9A 00";
2019-03-18 20:14:35;"10";"50";"B5 05";"02 18 00 34 00 00 00";
2019-03-18 20:14:35;"10";"50";"B5 05";"02 30 01 48 00 01 01 9A 00";
2019-03-18 20:14:37;"10";"50";"B5 03";"02 00 01 41 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:14:41;"10";"50";"B5 04";"01 18 E7 00 06 31 31 00 99 02 18 C1 00";
2019-03-18 20:14:43;"10";"50";"B5 03";"02 00 03 43 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:14:44;"10";"50";"B5 09";"04 0E 01 00 01 55 00 00 00";
2019-03-18 20:14:44;"10";"50";"B5 09";"04 0E 20 00 01 2E 00 00 00";
2019-03-18 20:14:44;"10";"08";"B5 10";"09 00 00 62 46 FF FF 00 FF 00 48 00 01 01 9A 00";
2019-03-18 20:14:44;"10";"50";"B5 05";"02 18 00 34 00 00 00";
2019-03-18 20:14:45;"10";"50";"B5 05";"02 30 01 48 00 01 01 9A 00";
2019-03-18 20:14:47;"10";"50";"B5 03";"02 00 01 41 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:14:50;"10";"FE";"B5 05";"02 04 00 0B AA";
2019-03-18 20:14:51;"10";"50";"B5 04";"01 18 E7 00 06 31 31 00 99 02 18 C1 00";
2019-03-18 20:14:53;"10";"50";"B5 03";"02 00 03 43 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:14:54;"10";"50";"B5 09";"04 0E 01 00 01 55 00 00 00";
2019-03-18 20:14:54;"10";"50";"B5 09";"04 0E 20 00 01 2E 00 00 00";
2019-03-18 20:14:54;"10";"08";"B5 10";"09 00 00 62 46 FF FF 00 FF 00 48 00 01 01 9A 00";
2019-03-18 20:14:54;"10";"50";"B5 05";"02 18 00 34 00 00 00";
2019-03-18 20:14:55;"10";"50";"B5 04";"01 26 D9 00 07 02 02 00 30 01 CB 01 11 00";
2019-03-18 20:14:55;"10";"50";"B5 05";"02 30 01 48 00 01 01 9A 00";
2019-03-18 20:14:57;"10";"50";"B5 03";"02 00 01 41 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:14:59;"10";"50";"B5 05";"05 3C CB 01 CB 01 F3 00 00 00";
2019-03-18 20:15:01;"10";"50";"B5 09";"04 0E 01 00 01 55 00 00 00";
2019-03-18 20:15:02;"10";"50";"B5 09";"04 0E 20 00 01 2E 00 00 00";
2019-03-18 20:15:02;"10";"50";"B5 04";"01 18 E7 00 06 31 31 00 9B 02 18 ED 00";
2019-03-18 20:15:02;"10";"08";"B5 10";"09 00 00 62 46 FF FF 00 FF 00 48 00 01 01 9A 00";
2019-03-18 20:15:03;"10";"50";"B5 03";"02 00 03 43 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:15:04;"10";"50";"B5 05";"02 18 00 34 00 00 00";
2019-03-18 20:15:05;"10";"50";"B5 05";"02 30 01 48 00 01 01 9A 00";
2019-03-18 20:15:07;"10";"50";"B5 03";"02 00 01 41 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:15:10;"10";"08";"B5 12";"02 00 64 AE 00 00 00";
2019-03-18 20:15:11;"10";"50";"B5 09";"04 0E 01 00 01 55 00 00 00";
2019-03-18 20:15:12;"10";"50";"B5 09";"04 0E 20 00 01 2E 00 00 00";
2019-03-18 20:15:12;"10";"50";"B5 04";"01 18 E7 00 06 31 31 00 9B 02 18 ED 00";
2019-03-18 20:15:12;"10";"08";"B5 10";"09 00 00 62 46 FF FF 00 FF 00 48 00 01 01 9A 00";
2019-03-18 20:15:13;"10";"50";"B5 03";"02 00 03 43 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
2019-03-18 20:15:14;"10";"50";"B5 05";"02 18 00 34 00 00 00";
2019-03-18 20:15:15;"10";"50";"B5 04";"01 26 D9 00 07 02 02 00 30 01 CB 01 11 00";
2019-03-18 20:15:15;"10";"50";"B5 05";"02 30 01 48 00 01 01 9A 00";
2019-03-18 20:15:18;"10";"50";"B5 03";"02 00 01 41 00 0A FF FF FF FF FF FF FF FF FF FF 0F 00";
Do you have any hint for me?
With best regards,
Martin
