Ebus vaillant how-to VR90 VRC630 VHR BE 35S
First of all, Openhab is so wonderfull! I try to bind all my smart stuff in my house and after a lot of google-ing and with a lot of try-and-error i succeeded to configure all my nikobus and zwave stuf in my house. I started with raspberry pi but it is to slow for full functional house! Now I come to the part “Vaillant Ebus”
For this i cant figure out how to make it work :frowning:
My setup:
Vaillant VR90 thermostat
Vaillant VRC630 bus modular controlsystem
Vaillant VHR BE 35S
The connection with openhab is build with a ebus coupler:
http://www.eservice-online.de/produkte/ebus/295/ebus-koppler-rs232
openhab is running on Linux.
My config file:
ebus:serialPort=/dev/ttyUSB0
# TCP Hostname and Port
# Warning: Only use ebus.hostname or ebus.serialPort
#ebus:hostname=myhostname
#ebus:port=5000
# Custom parser configuration file
# This example tries to load a configuration ${openhab_home}/configurations/ebus-config.json
 ebus:parserUrl=platform:/base/../configurations/ebus-config.json
# Load different parser, currently supported
# >> common - All telegrams defined by eBus interest group
# >> wolf - All telegrams specified by Wolf/Kromschr��der
# >> vaillant - All telegrams specified by Vaillant
# >> testing -  All unknown or test telegrams
# >> custom - Use configuration defined by ebus:parserUrl
# default uses common and all vendor specified telegrams
ebus:parsers=common,vaillant,testing,custom
# Set the sender id of this binding, default is "FF"
# ebus:senderId=D5
I played a bit with senderId and parser but this seems to do nothing?? So i have no idee where to use for.
I see logging but only WARN and always invallid CRC??
Can someone help me a little bit?
My log:
2015-12-21 17:03:57.891 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘home.items’
2015-12-21 17:03:58.542 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
2015-12-21 17:04:02.041 [INFO ] [.o.b.ebus.internal.EBusBinding] - Update eBus Binding configuration …
2015-12-21 17:04:02.624 [INFO ] [.o.io.habmin.HABminApplication] - Started HABmin REST API at /services/habmin
2015-12-21 17:04:03.032 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 00 00 00 0E A1 00 00 41 00 00 00 00 00 18 00 00 00 01 00 00 00 00 00 08 00 00 00 00 AA
2015-12-21 17:04:03.508 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AE D5 BA AB EE EA BB AA
2015-12-21 17:04:04.585 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: EE FD D5 D5 BB AA
2015-12-21 17:04:04.969 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 D7 82 EA EB 00 00 00 00 00 00 00 80 D3 00 01 00 20 00 00 00 00 00 00 00 00 00 00 00 AA
2015-12-21 17:04:05.506 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: B4 00 00 BA 12 00 00 22 00 00 12 00 00 00 00 00 00 00 00 00 00 00 00 F8 AA
2015-12-21 17:04:05.838 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FA EA AB 00 00 B5 00 00 00 00 00 00 00 43 00 C8 00 00 08 00 00 00 00 00 BA AB EA AA
2015-12-21 17:04:06.436 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F5 AE AE AE EA EA AA
2015-12-21 17:04:06.795 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AE EA DD D5 D7 AF D5 AA
2015-12-21 17:04:07.482 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: EB 00 00 88 6B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 00 00 23 00 00 00 80 00 00 00 00 00 00 F5 DD FD AF 00 00 00 00 00 00 00 00 00 17 00 00 00 00 26 00 00 40 84 46 00 00 00 00 00 00 00 F5 D5 AB D5 00 00 21 00 00 00 00 00 00 00 00 00 00 80 00 A3 00 00 FF D5 AA
2015-12-21 17:04:07.912 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2015-12-21 17:04:08.060 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘Motion.rules’
2015-12-21 17:04:08.078 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AE BA DD EB AF AB AA
2015-12-21 17:04:08.180 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘Heating.rules’
2015-12-21 17:04:08.707 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2015-12-21 17:04:08.793 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: A1 04 00 00 00 00 00 00 55 00 00 C0 00 00 5D 00 C0 AA
2015-12-21 17:04:08.803 [DEBUG] [.o.b.n.internal.NikobusBinding] - Started Command Receiver Thread.
2015-12-21 17:04:08.805 [DEBUG] [.o.b.n.internal.NikobusBinding] - Started Command Sender Thread.
2015-12-21 17:04:08.809 [DEBUG] [.n.i.core.NikobusCommandSender] - Command sender started.
2015-12-21 17:04:08.810 [DEBUG] [.o.b.n.internal.NikobusBinding] - Refresh service started. Will refresh a module every 600 seconds.
2015-12-21 17:04:08.851 [DEBUG] [.o.b.n.internal.NikobusBinding] - Refresh service started. Will refresh a module every 601 seconds.
2015-12-21 17:04:08.863 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Found port: /dev/ttyUSB1 x null
2015-12-21 17:04:08.875 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Port not found during first attempt : null
2015-12-21 17:04:08.886 [INFO ] [.o.b.n.i.core.NikobusInterface] - Connected to serial port ‘/dev/Nikobus’
2015-12-21 17:04:08.886 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Sending : ++++
2015-12-21 17:04:08.893 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Sending : ATH0
2015-12-21 17:04:08.902 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Sending : ATZ
2015-12-21 17:04:08.905 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Sending : $10110000B8CF9D
2015-12-21 17:04:08.925 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Sending : #L0
2015-12-21 17:04:08.929 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Sending : #E0
2015-12-21 17:04:08.933 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Sending : #L0
2015-12-21 17:04:08.937 [DEBUG] [.o.b.n.i.core.NikobusInterface] - Sending : #E1
2015-12-21 17:04:08.941 [INFO ] [.o.b.n.i.core.NikobusInterface] - Connected to Nikobus :slight_smile:
2015-12-21 17:04:08.949 [DEBUG] [b.n.i.c.NikobusCommandReceiver] - Received NikobusCommand [command=$0511, repeats=1]
2015-12-21 17:04:09.306 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 B0 45 1F 00 00 00 DF 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 AA
2015-12-21 17:04:09.381 [INFO ] [b.s.internal.SysteminfoBinding] - Using Sigar version 1.6.4.129
2015-12-21 17:04:09.393 [INFO ] [.service.AbstractActiveService] - Systeminfo Refresh Service has been started
2015-12-21 17:04:09.939 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 DD D5 DD 00 00 20 00 00 00 41 00 00 00 AA
2015-12-21 17:04:11.231 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D7 D7 F5 FD AB F5 D5 00 00 00 00 00 00 21 92 00 00 00 84 BA D7 F5 AA
2015-12-21 17:04:11.449 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 00 F4 00 00 00 00 00 00 00 34 00 00 00 00 00 00 00 00 10 08 FF F7 D5 AA
2015-12-21 17:04:12.035 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 04 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 E2 FD D5 FD FF 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 60 00 FF FF D5 DD EA AA
2015-12-21 17:04:12.650 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: EC FD D7 FD DD AE 98 00 00 00 00 9A 00 00 00 00 00 FE FF FF BB 40 E2 D5 D5 AA
2015-12-21 17:04:13.011 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BA 00 56 D4 00 60 D9 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 80 D5 AA
2015-12-21 17:04:14.089 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BB D5 F5 D5 FD AA
2015-12-21 17:04:14.689 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD D5 FF EA AF F5 AB F5 AB AA
2015-12-21 17:04:15.178 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F5 00 00 00 00 12 00 70 37 00 00 60 00 00 00 00 A0 00 01 00 00 BA AE 00 00 6A 00 00 00 00 00 04 00 00 00 01 66 AA
2015-12-21 17:04:15.872 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD FD EA AE EA EB 00 00 00 00 00 00 00 00 00 E2 FF F5 D0 EA F5 BA AA
2015-12-21 17:04:16.395 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: EA D5 BA 00 C6 1F 00 00 00 00 D5 EB AB BA FD D5 F5 FD AA
2015-12-21 17:04:17.163 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D7 00 00 00 41 00 00 00 00 00 2D 80 00 98 00 D5 AB F5 AE BA EA FD FD EA 00 00 F4 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 88 00 40 00 00 00 00 00 00 00 48 00 00 00 00 82 00 00 00 00 AA
2015-12-21 17:04:17.358 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 00 00 06 01 00 88 00 00 00 00 00 00 00 00 60 00 68 00 01 00 00 C3 AA
2015-12-21 17:04:17.594 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BE EA 00 C0 18 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AA
2015-12-21 17:04:18.033 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F7 FD D5 FD FF FF FF D5 D5 AA
2015-12-21 17:04:19.070 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 00 56 00 00 00 00 00 84 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 CE F5 00 42 52 00 B2 00 00 00 00 00 00 00 00 00 00 00 80 00 00 06 00 19 00 00 00 00 00 98 D1 00 00 00 00 00 00 08 00 00 00 AA
2015-12-21 17:04:20.309 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 20 00 7C 00 00 22 E0 00 00 00 00 00 22 FC D5 F5 DD AB F5 F5 D5 FF F7 AF D5 F7 BE 81 FA EA D5 AE F5 00 01 00 00 00 00 00 00 80 00 00 00 88 00 00 00 00 FE FF AA
2015-12-21 17:04:20.628 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BA D5 F5 AF BB D5 AA
2015-12-21 17:04:21.260 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BA D5 00 00 AB 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 40 00 00 00 D5 F5 D5 AA
2015-12-21 17:04:22.738 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: EA DD FF D5 D0 FD F5 EA F5 AA
2015-12-21 17:04:23.138 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD 00 00 00 00 00 F1 24 00 22 00 8C 00 00 00 00 00 FF D7 D5 F5 AA
2015-12-21 17:04:24.176 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 D5 FD FD F5 F5 D5 D5 AB AA
2015-12-21 17:04:25.055 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BE D5 FF 80 D7 FD FD D5 DD F5 F5 F5 D5 D5 AE AA
2015-12-21 17:04:25.158 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 04 00 00 00 00 88 B3 00 D0 00 E2 AA
2015-12-21 17:04:25.569 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FF FD D5 FD D5 F0 F5 D7 00 AA
2015-12-21 17:04:25.651 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 00 21 00 00 00 00 00 AA
2015-12-21 17:04:26.489 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD EE FF DD D5 F5 AA
2015-12-21 17:04:26.809 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: DD FD F5 F7 FD AA
2015-12-21 17:04:27.004 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: DD 00 00 00 00 00 05 2C 00 10 00 00 00 00 00 00 00 E2 AA
2015-12-21 17:04:27.320 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D7 F7 00 00 B7 00 00 1A 00 12 00 80 00 00 00 00 89 00 00 AB F5 AA
2015-12-21 17:04:27.878 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD DD D5 86 FD BA FD D7 AF D5 AA
2015-12-21 17:04:29.900 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: EA A8 22 00 00 44 00 00 00 00 00 00 0A 00 00 F5 FF F5 BB C4 90 00 00 00 00 BF 00 30 00 00 00 00 00 00 00 00 44 00 00 00 FD D5 C0 FD FD F5 BA AE DD F5 FF D5 F5 F7 BA AB FD AA
2015-12-21 17:04:30.436 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 FD F5 D5 BA F5 DD 00 00 6A 00 48 00 00 00 00 00 E0 DD BA AA
2015-12-21 17:04:31.115 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 FF FD F7 D7 FF FD FD FD FD FD D5 FD D5 AA
2015-12-21 17:04:31.434 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F5 D5 D5 FD DD AA
2015-12-21 17:04:32.433 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: DD D7 EE EA FF F5 D5 F7 AA
2015-12-21 17:04:33.074 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AB AE 00 00 B3 6D 23 14 00 00 65 00 00 00 83 00 F9 F5 F5 00 00 00 00 00 00 01 00 11 00 D0 FD D5 DD AA
2015-12-21 17:04:33.545 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 00 A8 00 00 00 00 00 00 80 00 A1 F5 F5 FD D5 AB 00 90 00 00 00 00 00 00 00 00 00 00 00 40 02 00 00 00 40 FC FF FD AA
2015-12-21 17:04:34.080 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 11 00 6F 94 00 00 70 05 00 00 86 00 00 02 00 00 00 00 00 00 AB DD 00 00 00 FB 00 00 00 00 00 00 00 00 1C 00 00 00 00 F1 D7 FD AA
2015-12-21 17:04:34.839 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F5 FF F5 FF BA FF FF BA FF D5 FD EF F7 F5 F5 AA
2015-12-21 17:04:35.301 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 D7 F5 EB 00 30 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 21 00 00 00 00 A8 F5 DD D5 AB AA
2015-12-21 17:04:35.539 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AE AB D5 FD D7 AA
2015-12-21 17:04:36.751 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 00 3F 6D 00 00 EC 00 14 00 00 00 29 00 00 00 00 00 FF D5 DD AE F2 D7 FF F5 BA BE F7 F7 FF D7 BA D5 F5 D5 DD D7 F7 AA
2015-12-21 17:04:37.044 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 00 60 00 B5 0A 00 00 2A 00 00 00 00 00 00 00 02 00 00 00 00 51 F5 EE AA
2015-12-21 17:04:37.635 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: DF 02 5C 00 00 00 02 7F A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 FD FD 00 00 B5 00 00 01 00 00 00 00 00 4D 10 A4 00 00 FF FD AB D7 AA
2015-12-21 17:04:38.433 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: A0 BB F5 D4 AB DF FF DD AF F5 BB AB FF AA
2015-12-21 17:04:38.713 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F7 D5 FD FF FF AA
2015-12-21 17:04:39.006 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D7 00 00 00 00 00 00 00 00 00 84 00 00 00 00 00 00 00 00 41 00 00 00 00 00 08 00 00 EB F5 D5 AA
2015-12-21 17:04:39.243 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 90 00 00 00 00 00 00 1A 00 00 00 00 00 00 00 D7 F5 D5 AA
2015-12-21 17:04:39.391 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: A5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 FF AA
2015-12-21 17:04:39.631 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: EA FF DD D5 FD AA
2015-12-21 17:04:40.446 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD BA D5 F7 EB FD BA FD FF 00 34 00 00 00 00 E1 00 00 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D4 AB DD AB AA
2015-12-21 17:04:40.806 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 DD F5 F5 FD AA
2015-12-21 17:04:41.014 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BB D5 00 00 D1 5F 00 70 00 00 00 A1 F5 AA
2015-12-21 17:04:41.525 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD F7 00 42 D0 00 00 00 00 00 40 00 00 00 FF BB DF 00 0D 00 00 00 00 00 00 00 00 06 00 00 00 00 49 40 00 01 00 00 00 00 00 01 40 00 00 00 AA
2015-12-21 17:04:41.805 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D7 DD FF EB F5 FF AA
2015-12-21 17:04:42.404 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD D5 BA D5 DD D7 FD D5 F7 FF F5 D5 AA
2015-12-21 17:04:42.724 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FF D5 D7 BA BB D5 AA
2015-12-21 17:04:43.205 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 D5 00 00 00 50 00 13 00 40 08 41 00 01 00 00 22 D7 FD BA F5 D5 BA AA
2015-12-21 17:04:43.604 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: DD F7 FF D5 F5 F5 FD AA
2015-12-21 17:04:44.163 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F5 D5 D5 FD AE FD F5 AE D5 D5 BA AA
2015-12-21 17:04:44.682 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD BA AB F5 DF AA
2015-12-21 17:04:45.064 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FF 00 09 00 00 00 0A 00 4C 00 00 00 00 80 00 00 00 00 00 00 00 00 00 FF AA
2015-12-21 17:04:45.278 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FA C0 7D 00 BF B5 00 00 C0 00 00 81 00 45 AA
2015-12-21 17:04:45.638 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AB D7 FF EA AB AA
2015-12-21 17:04:46.157 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: B5 DD F5 FD FD FF BE F5 AA
2015-12-21 17:04:46.556 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AB FF BA DF FD EE FF AA
2015-12-21 17:04:46.991 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F5 EA AE F5 FD DF 00 2B 00 00 00 00 00 00 00 5B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AA
2015-12-21 17:04:47.505 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 FF 00 00 E8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 0A 00 00 51 FF FD FD D7 D5 FD AB F5 AA
2015-12-21 17:04:49.525 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F7 FD 8A FD EA F5 DD C8 FF AB F5 D5 AE D7 FF D5 00 00 1B 00 00 01 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 02 00 D5 D5 DD F5 00 00 84 00 00 80 E8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FD BA FF FD D7 D5 FD D7 F5 FD F5 AA
2015-12-21 17:04:50.205 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: EA D5 F5 F5 AB FD AE D5 D5 FA AF D5 AB AB D5 D5 AA
2015-12-21 17:04:50.804 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 D5 BB D5 AB FA F5 F5 AA
2015-12-21 17:04:51.252 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F5 82 D5 DF AB FF 00 00 6D 00 00 49 00 10 00 38 FF F7 AA
2015-12-21 17:04:51.976 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 01 00 62 00 00 00 00 00 00 00 00 00 C4 F5 D5 D5 00 01 B5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF D5 EB F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 48 00 00 00 00 08 00 F8 F5 AA
2015-12-21 17:04:52.866 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BA AE FD FF F7 FF F5 D5 BA F5 F5 F5 FA FF BA BA 00 AA
2015-12-21 17:04:53.015 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: C0 00 00 00 00 10 00 00 02 22 00 01 00 00 AE AA
2015-12-21 17:04:53.694 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 D0 80 D5 EB D7 F7 BB DD D7 DD DD AA
2015-12-21 17:04:54.372 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: D5 AE FD AE FD EA D5 AA
2015-12-21 17:04:54.812 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F7 EA D7 D2 FA F5 D5 F5 F5 AA
2015-12-21 17:04:55.849 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD BE C3 EB D5 BA AA
2015-12-21 17:04:56.607 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AE D5 DD EE BA D5 FF FD FF D5 FF F7 D5 DF D5 F5 DD AA
2015-12-21 17:04:57.335 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AB D5 DF F5 00 00 03 00 02 0C 00 00 22 00 00 00 00 00 00 00 00 20 00 00 00 10 00 00 00 00 00 00 00 F4 F7 DF BA 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 F5 AA
2015-12-21 17:04:57.811 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 24 26 ED 00 00 00 00 00 00 01 00 23 00 00 D2 00 00 00 00 00 00 00 00 00 00 56 DF FD F5 D5 D5 D5 AA
2015-12-21 17:04:58.090 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD FD F5 FD F5 AA
2015-12-21 17:04:58.823 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FF D5 FF F5 DF F5 EA 00 00 00 62 00 14 10 00 00 00 8B 30 00 00 00 02 00 00 24 00 F9 F5 D5 AA
2015-12-21 17:04:59.805 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram answer-crc invalid, skip data!
2015-12-21 17:05:00.502 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: AB BA F5 00 00 00 00 00 81 00 00 00 00 00 E2 D5 FF F5 AA
2015-12-21 17:05:01.061 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: F5 FD 84 F7 FF AA
2015-12-21 17:05:01.301 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: BA F5 F5 D5 BA AA
2015-12-21 17:05:02.418 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FD D5 BB F5 D5 FF EA BA FE BE D7 AA
2015-12-21 17:05:02.965 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: 00 00 00 20 10 00 00 00 00 10 10 E8 00 80 AA
2015-12-21 17:05:03.534 [WARN ] [.ebus.internal.utils.EBusUtils] - EBus telegram sender-crc invalid, skip data! Data: FF 00 00 00 5B 00 00 00 00 00 00 00 FD DD D7 FD FD AA
zuviel crc.fehler?
hab ich hier gelesen, poti runterdrehen./bus-ankopplung anpassen:
“Wenn die Hardware läuft, sieht man jetzt eine Menge Daten über den Bildschirm flutschen. Da druckt ebusd alles aus, was am eBus aktuell passiert. Wichtig: Wenn keine Daten zu sehen sind, muss man evtl. den Poti (Regler) am eBus-Koppler etwas drehen, so dass zwischen den eigentlichen eBus-Telegrammen viele AA-Zeilen (Syncs) zu sehen sind, aber keine zahlreichen CRC-Fehler.”
