OH3.2, echo dot gen 4, SmartHome/J Amazon Echo Control Binding version 3.2.13:
I noticed that the playAlarmSound & notification volume channel are not working anymore.
I do not see any error messages in the log files, but any change of the notification volume is not visible within the alexa app and if I set an alarm sound (e.g. ECHO:system_alerts_repetitive01), than no sound is played by my echo.
Any ideas on where to start in order to fix this issue?
Since when do you experience these issues? If a very short time, it could be that Amazon has issues. If it’s more than a week, they probably changed something and we’ll need to adapt the binding.
It took a while that I found some time to test this again:
the playAlarmSound channel is still not working and I do not see any error messages in the log files.
the notificationVolume channel is working, the issue was related to the alexa app not updating the volume automatically and you need to refresh the app in order to see the change.
If something related to playAlarmSound channel would have changed on Amazon side than maybe others would also posted something; therefor I am wondering why there is no other post & no error messages in my log files..
Unfortunately I don’t have a Gen.4 device, so I can’t check. I added the device, linked the playAlarmSound channel to a String item and used the console openhab:send EchoEsszimmer_AlarmSound "ECHO:system_alerts_repetitive01" and that worked. Maybe it depends on the commands send before or some other setting.
I do have the same Problem. The “PlayAlarmSound” option is not working with a Gen4 “Echo Dot”, while others - like the TTS - are working as expected.
I have tried to use it in a rule and directly via console, both ways are not working.
