OpenHab 2.3 on RasPi 3 with the 2.3 Version of the Amazon Echo binding with an Echo Dot.
The whole echo binding works like a charm, but when I want to send commands to the item linked to the binding’s PlayMusicVoiceCommand, i am getting the following error:
018-07-28 23:39:35.111 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.handler.EchoHandler@a84e39': POST url 'https://alexa.amazon.de/api/behaviors/operation/validate' failed: Bad Request
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.de/api/behaviors/operation/validate' failed: Bad Request
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:404) [259:org.openhab.binding.amazonechocontrol:2.3.0]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:286) [259:org.openhab.binding.amazonechocontrol:2.3.0]
at org.openhab.binding.amazonechocontrol.internal.Connection.playMusicVoiceCommand(Connection.java:904) [259:org.openhab.binding.amazonechocontrol:2.3.0]
at org.openhab.binding.amazonechocontrol.handler.EchoHandler.handleCommand(EchoHandler.java:267) [259:org.openhab.binding.amazonechocontrol:2.3.0]
at sun.reflect.GeneratedMethodAccessor378.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh230]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [101:org.eclipse.smarthome.core:0.10.0.oh230]
at com.sun.proxy.$Proxy177.handleCommand(Unknown Source) [259:org.openhab.binding.amazonechocontrol:2.3.0]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [108:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [108:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at sun.reflect.GeneratedMethodAccessor276.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh230]
The Item definition is the following:
String Echo_Dot_LivingRoom_PlayMusic {channel="amazonechocontrol:echo:41d408e1:G090LF1181752CXT:playMusicVoiceCommand"}
I am sending a command to this item from the following rule:
rule "Testrule"
Item TestSwitch received command
Echo_Dot_LivingRoom_MusicProvider.sendCommand("Amazon Prime Music")
Echo_Dot_LivingRoom_PlayMusic.sendCommand("Eric Clapton")
So i don’t see what i am doing wrong here.
TTS works fine without any problems.
Does anybody else use this feature without any problems?
